Old 09-08-2005, 07:22 PM
bogeyinthekeys bogeyinthekeys is offline
Rep: 10 Posts: 9
boat material / furniture material
Hi there,
I am new at this and am trying to educate myself on possible materials that I might use for a furniture design as it may relate to boat design process. I need to find a material that is flexible(1/4" to 1" in thickness), and that can be bend to different radiuses to fit into a jig. I guess the form could be hardened with an epoxy. The stool must also accomodate the weight of the person sitting on it.
Can anyone help me out ?
Heidi
Old 09-09-2005, 08:48 AM
Bergalia's Avatar
Bergalia Bergalia is offline
Rep: 254 Posts: 2,517
furniture materials
Bogie - most long grained timbers (especially pine) when steamed can be bent with care. But for making a stool, cane when steamed, bends easiest of all. However its boat building qualities are questionable (without a ton of caulking).
If you're working with 1/4 inch thickenesses try a decent ply, and laminate it to build up strength. Now that, you can use for boat building.
Old 09-09-2005, 09:26 AM
JR-Shine JR-Shine is offline
SHINE
Rep: 50 Posts: 282
you can also laminate 3/16" mahogany of meranti plywood over a honeycomb (3/4") core. It would be very light and strong.
Old 09-09-2005, 09:48 AM
John ilett's Avatar
John ilett John ilett is offline
Rep: 23 Posts: 131
There are quite a few varietys of honeycomb type core panels made just for this. Cores can be coated paper, nomex honeycomb, alloy honeycomb, plastic honeycomb etc. Skins can be fglass, alloy, formica, etc.
I have worked with the glass skinned alloy honeycomb which you can rout or cut grooves in one face then bend on a jig with a filler in the cuts. Once set it stays.
http://www.plascore.com/
http://www.tricelcorp.com/
http://www.nida-core.com/default.asp
Of course there are plenty of ways to make a bent sandwich also, foam, ply, glass..............
Old 09-09-2005, 12:22 PM
nero nero is offline
Rep: 112 Posts: 624
Or you can laminate thin strips of wood with epoxy. Add some uni-directional fiberglass or kelvelar on the outside if needed for extra strength.
Old 09-09-2005, 01:03 PM
Rep: 10 Posts: 9
furniture material
thanks a million !
you don't know how great it is to talk to people who know what they are doing. I will check out the sites. Is the material expensive ?
there aren't many women doing this you know !!
Heidi
Old 09-09-2005, 01:47 PM
Rep: 10 Posts: 9
furniture material
Hi again,
That Nida-core Structiform is right up my alley - saw a photo of a man standing on a piece. That might be what I will use depending on the minimum radiuses capabiliy.
Heidi
Old 09-10-2005, 09:29 AM
Rep: 10 Posts: 9
nida-core structiform
Hi there,
Thanks so much for the information - nida-core is sending me a sample to check out, it looks like it will be what I need. I can laminate 2 skins to the bent honeycomb material (a la eames bent wood furniture) to achieve the look.
I will let you know how it goes, can't wait to work with the stuff.
Heidi
Hull speed Mike D Boat Design 33 02-27-2011 02:20 AM
Chrysler Boat Corporation Info captdave311 Powerboats 4 04-14-2008 09:54 AM
Option One - how big Willallison Option One 43 12-20-2005 06:44 AM
Boat Design Proj designfreak Boat Design 31 04-15-2005 03:20 AM
Naval Architect Book? Bill_Smith Boat Design 16 11-17-2004 11:08 AM
