Old 04-19-2010, 11:27 PM
watchkeeper watchkeeper is offline
Rep: 41 Posts: 145
Blasted alumium hull finish
Got a curly one
I have a client that wants a blasted finish on his new alloy hulls to achieve a seudo matt military type finish. We experimented with various oxides, glass bead etc to get the shade of grey correct. Client's happy but personally I dont like the coarse surface finish and possible changes that will occur with exposure.
If anyone has another method (non paint)that produces a flat grey military looking and a proven durable finish I would be interested in learning.
Thanks
Old 04-20-2010, 12:00 AM
mark775
As you know, weather causes a patina that will acheive the desired effect. I would convince him of that.
Old 04-20-2010, 09:50 AM
alan white's Avatar
Rep: 1211 Posts: 3,325
Baking soda is a good fine blast medium, I've heard. I haven't used it but you might check it out. My guess is it will leave a more uniform, matt finish.
Old 04-20-2010, 11:49 PM
Rep: 41 Posts: 145
I have used baking soda on several restoration projects both marine and architectural (historic bldgs) Its great if envioroment is protected, residue salts go down the drain and it dosent damage substrate - old wrought iron/glass windows, alloy or FRP hulls.
I tried it out for this project - on marine alloy it came out bright rather than a darker grey shade. If you want to remove anti foul between tides with a ready to prime finish its bullet proof.
Old 04-28-2010, 07:11 AM
AWH AWH is offline
Rep: 10 Posts: 7
The best acid to vlean aluminum is the Hydro Fluorhidric, combined with Phosphoric acid, they brighten alumminum. I suggest to look for aluminumm cleaners extra strong. These cleaners are used for alumminun boxes on trucks. Also they are used for cleaning of refrigeration conderses (aluminnum fins on copper). Look for the strong formulation
Hydro Fluorhidric is a dangerous product
Old 04-28-2010, 08:18 AM
swabbie swabbie is offline
Rep: 24 Posts: 56
HF is very dangerous, eat flesh faster than hungry croc, the reason I never use it plus its hard to control the over all consistency of the etch.
Old 04-28-2010, 08:27 AM
AWH AWH is offline
Rep: 10 Posts: 7
Its important that once HF has been used to remove the oxidisation, that a clear sealer be applied such as Nyalic or similar, which stops any further oxidisation.
Hull finish on high speed hull. Polished or Matt? Sooty Boat Design 2 02-03-2008 12:08 PM
28" bare hull to finish filiperosa Fiberglass and Composite Boat Building 5 06-13-2007 01:37 AM
finish the finish?? richard567 Fiberglass and Composite Boat Building 0 05-31-2007 10:38 PM
Occume finish WoodButcher Wooden Boat Building and Restoration 2 08-22-2004 12:50 AM
Boat Finish Materials 4 03-30-2003 08:24 PM
