Old 02-13-2004, 07:20 PM
Rep: 1397 Posts: 7,215
black stuff on new steel
What is the chemical composition of the black stuff on new steel? I know paint doesn't adhere to it and needs to be sandblasted.
Old 02-13-2004, 07:54 PM
Roy Abrams Roy Abrams is offline
Roy Abrams
Rep: 10 Posts: 8
iron oxide (rust)
roy
Old 02-14-2004, 09:50 AM
Polarity Polarity is offline
Rep: 148 Posts: 480
Mill Scale : FeO
Old 08-21-2005, 03:53 AM
Bergalia's Avatar
Bergalia Bergalia is offline
Rep: 254 Posts: 2,517
Black stuff on new steel
Or if the steel is imported from overseas - it could be lanolin. That's the stuff that makes sheep waterproof - and is a great anti sea-water preservative for ferous metals. Used on all export vehicle parts.
Old 08-21-2005, 10:31 AM
D'ARTOIS D'ARTOIS is offline
Rep: 311 Posts: 1,069
As a college student, I worked in the largest Dutch steel mill that was next to our holidayresort on the beach.
I did hundreds of odd jobs among them the packaging of the steel sheets and coils, some weighing more than 40 tons.
It is as Bergalia says the anti-rust coating that is sprayed on the coils before they are packed. Sometimes they contain also the graphite-based grease deposits from the qualitycontrol and overpacking units. It is definately not rust, that you should have discovered and established right away.
Old 08-22-2005, 08:56 AM
nero nero is offline
Rep: 112 Posts: 624
not rust. Have used quite a bit of new steel in France. It seems to be an oil or some type. I use white spirit (mineral spirits) and a clean rag to wash/wipe it off with. This works well for preping the weld area as well as degreasing before painting with Ferriprime and other oil based paints.
Old 08-22-2005, 10:09 PM
capt'n ron capt'n ron is offline
Registered
Rep: 10 Posts: 33
gonzo, if you're asking about the hard black scaley " skin" that's on new steel it is as polarity stated, called " mill scale". i don't know exactly how it forms other than it is from when the white hot steel is shaped under a roller, the very surface is compressed and it scales when it cools. you are correct it must be blasted or ground off . it wrecks havoc with welding, especially if you are using a small 110 v. type. evidently, it must also be non-conductive when thick enough. i am a certified welder and fight with the stuff all the time. i have seen it thick enough to shunt the starting drive of a good welder and not be able to strike and arc at all, until a spot is chipped or ground off where you are going to weld.another spot to clean off is where the ground clamp will be. paint and primers also will not hang on to it. i am around commercial const. everyday and the painters will refuse to paint something untill it is sand blasted, even with tinemic(sp?) paint.
Old 08-24-2005, 04:27 PM
gregsport gregsport is offline
gregsport
Rep: 10 Posts: 2
Good question, and answer by capt'ron; I use 7/16" o.d. tubing ('dom', drawn over mandral) from an aircraft supplier, and always thought it was a preservation coat, but mill scale seems credible, imho.
Old 08-24-2005, 05:52 PM
Capt'n Ron is correct, it is mill scale. I couldn't find the right word for it. Before sandblasting, in earlier days, one left the hull bare outside for some time, so that the mill scale could rust away. There are also deposits from the uncoiling machines, and later on from the cold rolling plant, where most of the mill scale will come off.
Old 08-24-2005, 08:49 PM
Registered
Rep: 10 Posts: 33
thanks guys,
gregsport, all of the mech. tubing (both d.o.m. and e.w.s.) i've worked with was relatively clean, except for occasionaly, an oily black coating, a lubrication from being formed. you are correct that it is left on to act as a protective coating, but a good wiping with laquer thinner or similar leaves the tubing shiney clean, ready to weld. mill scale is actually part of the steel, the very surface, super compressed from the high pressure under the forming roller and is sort of bonded to the surface, sort of the same way welding slag is stuck down, some of it will pop off as it cools, the same as welding slag, but allot of it stays put and is a real p.i.t.a. to get off without the right equipment. if left in the weather, rust forms between it and the parent steel and it eventually falls off. if you look at a large welded structure left out in the weather for a long time, there will be a dark outline of the structure on the ground, that's the mill scale that fell off from the structure rusting. the best medium for blasting it off is carborundum granules, but it's pricey stuff.
Durable Steel Hulls Wynand N Metal Boat Building 11 01-27-2009 07:19 PM
Stainless steel / Aluminum hendrikus Boatbuilding 5 06-30-2006 07:40 PM
255' Three-Masted Steel Barkentine for sale Yachting Marketplace 0 02-09-2005 10:35 PM
Steel sailboat mast Gerald Niff Boat Design 4 08-11-2004 07:10 AM
Steel and plywood hull? pdvjak Boatbuilding 1 02-02-2003 12:12 AM
