Old 09-07-2010, 08:35 AM
fg1inc
Probably not a good idea. All the newer stitched fabrics we've tried had a stitching that was a little too loose in the first place. This meant that when using a bubble buster roller, the threads were constantly getting caught on the roller and causing all kinds of problems. So if you remove the mat the stitching is going to be even looser and cause even more headaches.
That was one of the beauties of the Knytex, trouble free tight stitching.
Old 09-07-2010, 09:33 AM
Eric Sponberg's Avatar
Rep: 2464 Posts: 1,381
Originally Posted by CatBuilder View Post
Thanks for that source (Merritt Supply).
Quick question for anyone: Can I remove the mat from the back of a cloth myself by breaking the stitching, or is the same loop of stitching holding the entire thing together?
I believe the same stitching is used to stitch the lot together. But you can get the fabrics without the mat. Generally, a 17 oz/sq.yd double-bias fabric without mat would be called DB1700 or DB170, whereas with the mat they are called DBM1708.
The distributors are there for a reason--they buy and sell wholesale to builders so that the manufacturers don't have to deal with the vagaries of dealing directly with the end users. It takes a distributor to make the on-site calls and to stock the products in regional wearhouses. Deal with the distributors--the manufacturers really aren't equipped to deal direct with end users.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Old 09-26-2010, 08:07 PM
aussiebushman aussiebushman is offline
Innovator
Rep: 72 Posts: 102
Biaxial is sometimes called "double bias" and is generally supplied as a woven cloth. Fibreglass International here in Australia has all of the mats and cloths, including carbon fibre and I'm pretty sure they have a US company/affiate. Try a search for FGI
Alan
Old 09-26-2010, 09:55 PM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
..also try DIAB, have a yap with the designer about what you can get local and at the right price too, I am sure he can accomodate whatever you can econimically purchase without insisting on a certain material, there are alternatives....
Old 10-02-2010, 01:04 AM
tunnels tunnels is online now
old one !
Rep: 343 Posts: 1,520
Depending on the weight of the matt why bother ?
How many layers are you looking at laying ??
Use it Matt side up and peel ply ! Gives a beautiful smooth finish and the peel ply will get shot of a good % of the surplus resin anyway !!
Making beautiful boats is a passion never a chore !
Old 10-02-2010, 01:07 AM
Landlubber's Avatar
...yep, do it, why waste the material anyhow....
Old 10-02-2010, 03:29 AM
Vulkyn's Avatar
Vulkyn Vulkyn is offline
Rep: 529 Posts: 486
Im having the same problem with finding the material mentioned in the post, worst still most of the suppliers dont even know what Biaxial, Triaxial, woven or fabric is !
Just matt matt matt and more bloody matt ...
The Mummies Dummy guide to boat building stuff!!!
"All of us could take a lesson from the weather. It pays no attention to criticism."
"Learn wisdom when you can its gona help you out some day in your life"
Old 10-02-2010, 03:56 AM
old one !
Its one of the reasons i built a couple of boats just using unidirectional Glass with a 125 gram csm on the back . Worked out fine for what i was doing ! Basically i made my own matt's rather that waiting for some sales person that didn't know the difference between **** and chewed dates ! Sorry for the pun!
Old 10-03-2010, 03:40 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 987 Posts: 1,178
Vulkyn: Talk to Selcom in Italy for multiaxial fabrics (www.selcom-srl.com). They can supply to Egypt.
  #25
Old 10-03-2010, 04:44 AM
Vulkyn's Avatar
Rep: 529 Posts: 486
Thx Herman !! Will contact them ! The west system agent told me to go online get the part number and tell them which items i need (maybe they dont want to break a sweat) or they just dont know what biaxial tape and biaxel fabric are.
  #26
Old 04-10-2011, 04:24 AM
FGM08 FGM08 is offline
Rep: 10 Posts: 6
Biaxial usually means 0/90 degree, double bias should be +/-45 degree, both of them can be made with or without csm backing. If it is stitched with chopped strand mat on the back,we call it combo mat. For these two, they are produced by stitching two layers of roving together with polyester yarn. But for woven roving, it is simply weaved without any binder at all.
Offering fiberglass raw materials (tape, cloth, fabric, woven roving), vacuum bagging, balsa wood, etc. Email me:martha.lymy@gmail.com
Triaxial mat wetout jimrudholm Fiberglass and Composite Boat Building 8 05-15-2010 04:07 PM
Product Sourcing, Quality Suppliers of Hard to Find Items (PLEASE NO ADS!) ChrisN67 Boatbuilding 0 05-12-2010 06:09 PM
Hard to find parts OMC Sterndrive dang84119 Sterndrives 1 07-16-2006 02:30 PM
Triaxial versus woven....... Roly Fiberglass and Composite Boat Building 13 03-08-2006 03:08 AM
hard to find U.S. made cut thread wood screws luke bronco Boatbuilding 9 11-29-2005 05:59 PM
