Old 02-15-2010, 01:12 PM
evantica's Avatar
evantica evantica is offline
Rep: 42 Posts: 127
best protection for steel hull
I have read some treads "Powder coating" and so on...But it wont get any clearer to me?! What is the best protection for steelhull?
You can check my tread here Boat building in progress
Old 02-15-2010, 01:36 PM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,253
Powder coating requires the object to be heated to 200 C. for 10 minutes after electrostatically applying the powder.
I have a vivid imagination, but I doubt that shoving a steel hull in an oven is feasible.
Old 02-15-2010, 01:38 PM
souljour2000's Avatar
souljour2000 souljour2000 is offline
Rep: 156 Posts: 416
The individual plates would have have to be done before welding...
Old 02-16-2010, 01:07 AM
evantica's Avatar
Rep: 42 Posts: 127
(My guess to about the powder to, have done some A-Ford frames in the past!) The next best thing to protect the steelhull then? couple of years ago I put on some JOTUN coulor for the ship industri. but today I see the same Jotun falling off the hull. I put it on with a "Brush"( don't know the english word?) But obviosly couldn't get a real grip in the steelplates...Could need the help from you.
Hakan in Swe
Old 02-16-2010, 01:40 AM
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
no short cuts, blast, 75 microns dft zinc, 250 microns qualirty 2 pack epoxy like altex devoe 231, awlgrip number one etc Film thickness is everything on steel
search in the forum cos this has been covered a squillion times,
DFT= DRY FILM THICKNESS, as wet film thickness = wft
25 microns in one thou
Old 02-16-2010, 07:38 AM
jonr jonr is offline
Rep: 34 Posts: 246
Arc sprayed Zinc/ Aluminum(85/15) covered with paint.
Old 02-17-2010, 03:52 AM
evantica's Avatar
Rep: 42 Posts: 127
Thanks friends!
Old 04-03-2010, 03:54 PM
dskira dskira is offline
Rep: 1305 Posts: 1,372
Lead paint, or coal tar epoxy.
steel protection on inside of small enclosed spaces bigbear69 Metal Boat Building 8 11-22-2008 09:13 PM
Cement wash coating for steel protection MikeJohns Metal Boat Building 30 10-08-2008 05:39 PM
protection steel on the inside of an enclosed space bigbear69 Boatbuilding 1 08-10-2008 05:37 AM
Overuse of cathodic protection on aluminum or steel hulls Thunderhead19 Boat Design 6 02-28-2005 06:20 AM
Stainless steel protection on small vessel keels Gilmarine Fiberglass and Composite Boat Building 1 02-20-2005 10:51 AM
