Old 03-27-2011, 05:01 PM
goanywhere goanywhere is offline
Rep: 10 Posts: 9
Best fibreglass for kayak build
Hi all, any advice which weight and weave is best for sealing and strengthening a Stitch and Glue kayak build. I need cloth and tape. I looked into kevlar but it is too expensive for me.
Old 03-27-2011, 06:45 PM
Rep: 3125 Posts: 9,399
The best stuff is going to be expensive. You'd be best advised to use the fabric the design recommends. Each design will have a set of "scantlings" that cover how much of what and where to put it.
Which kayak are you building?
Old 03-27-2011, 09:23 PM
Rep: 10 Posts: 9
I haven't decided yet. It will definitely be S&G SOT, but I haven't decided on a design at this stage. I want to do an estimate of cost before I start. I have noticed on the various forums that people often change specs based on their personal preferences and experience.
Old 03-27-2011, 09:41 PM
You can make changes to a design, but the wise builder does so after consulting with the designer or by making similar substitutions (similar physical attributes). In other words, you can substitute pine for spruce, but it wouldn't be wise to substitute pine for oak.
In regard to changing scantlings (the dimensions and/or specifications) of things, again do so with care, if not designer approval. It's really easy to screw up a design making what seem to be innocuous choices, just to find you've created dramatically increased stress risers or localized loading issues. Most novices and backyard builders haven't a clue about engineering cantilever beams or point loaded structural elements, so it's best to stick with the plans.
Most canoes and kayaks are covered with light weight cloth. 4 to 8 ounce (140 - 270 g/m) 'glass cloth for sheathing with either regular cloth (not very strong) or biax (preferred) tape for the seams. Again, it depends on the design.
Old 03-28-2011, 09:40 AM
dinoa's Avatar
dinoa dinoa is offline
Rep: 61 Posts: 70
West, RAKA and MAS just to name a few epoxies.
Dino
Old 03-28-2011, 11:57 PM
Rep: 10 Posts: 9
Yes, it seems that trusting the experience of the designer is the way to go. Particularly the better known ones. Thanks.
Old 03-29-2011, 12:50 AM
Without a fair bit of engineering or practical industry experience, this is always the best advice. If you want a light and strong structure, it needs a some serious material properties understanding and engineering to specific strength goals.
Fibreglass kayak building lisa_w Fiberglass and Composite Boat Building 16 05-22-2012 08:26 PM
Hello Everyone , wanna build a Kayak cs2870 Open Discussion: All Things Boats & Boating 14 10-10-2010 06:41 PM
I wanna build a kayak. scott_n06 Wooden Boat Building and Restoration 5 07-10-2010 01:31 PM
New Here, Hi. Want to Build a Plywood Kayak fraggin Wooden Boat Building and Restoration 25 09-12-2008 08:46 PM
Kayak Build weissmarine Fiberglass and Composite Boat Building 13 08-05-2008 09:59 AM
