Old 01-17-2008, 02:43 AM
Whale1 Whale1 is offline
Rep: 10 Posts: 3
Below the water line Q-cell?
Hi just a question, iv just recently glassed on a live bait tank onto a pollyester hull. Ive glassed it on with polly. Im just wanting to know if i can use Q-cell as a filler to fair out the tape. Is Q-cell ok to use under the water line?
Old 01-17-2008, 06:49 PM
AroMarine AroMarine is offline
Rep: 10 Posts: 45
Q-cell and poly not a great choice below waterline. If you must use it an epoxy barrier coat will offer decent protection.
Old 02-19-2008, 04:22 PM
AA Fibreglass AA Fibreglass is offline
Rep: 10 Posts: 2
You could use Aerosil as your filler under the waterline.
AA Fibreglass Supplies
info@aafibreglass.com
http://www.aafibreglass.com/
Old 02-21-2008, 10:26 AM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 997 Posts: 2,298
FYI:
Descriptions of other "fillers" .......................
(3M Glass Bubbles - Q-Cells - Aerosil - Cab-O-Sil - Phenolic Microballoons):
http://www.shopmaninc.com/fillers.html
I can't tell from the site when, where and how to best use the products. Anyone want to chime in?
Thanks for the tips on Aerosil, that's a new one to me.
George: Architect (land lover type)
Hovercraft & Vintage Porsche Owner
http://www.boatdesign.net/forums/boa...ect-11973.html
Old 02-21-2008, 07:44 PM
Rep: 10 Posts: 45
Qcell, Microballoons, glass bubbles are fillers that are hollow spheres which makes them good for sanding and absorbing water therefore not a great choice under waterline. Polyester resins do not have the water resistant properties to seal and protect these from water intrusion. Epoxy is a much better choice. Cab-o-sil and Aerosil are fumed silica and create dense hard (hard to sand) puttys but are much more water resistant. Any polyester work below the waterline should be sealed with epoxy or gelcoat especially if it is structural.
Old 02-22-2008, 05:07 AM
kach22i's Avatar
Architect
When sanding do you need to use a respirator, or will a paper mask with rubber band do?
Old 02-23-2008, 09:19 PM
Rep: 10 Posts: 45
By the book probably a respirator but once every thing is cured it is fairly inert so good paper masks are ok. Some of the reading I have done seems say that the fumed silicas are not good to breath while mixing so I at least try to be down wind when mixing any of the fillers.
How can I re-establish a water line and boot stripe? Kaptin-Jer Fiberglass and Composite Boat Building 16 12-28-2007 07:19 PM
Sandblasting from the water line on down only. AdamFrench Metal Boat Building 3 05-24-2007 05:16 PM
Water line coating Sander Rave Materials 2 04-11-2006 04:21 AM
How to calculate balast ratio/ water line Ian Farnell Boat Design 6 10-07-2005 01:44 PM
mathmatical formula for water line of aluminum 25 footer Marvin Martian Boat Design 1 10-10-2004 11:56 AM
