  #31
Old 08-13-2009, 08:13 AM
adriano adriano is offline
Rep: 13 Posts: 15
Par,
I am little unclear when you mention bamboo veneer.
Do you mean to be used approx 45°?
as narrow planks of 3 or 6 mm.?
Is it possible to get such thinkness (by machine) out of bamboo? I know veneer only the traditional way from big round logs.
Thanks for yr further explanation
Adriano
  #32
Old 08-13-2009, 08:14 AM
apex1
Originally Posted by PAR View Post
Again as a core, it offers little benefit in epoxy strip plank construction. As a veneer it has possibilities.
Paul I doŽnt like to contradict you, but please would you tell me a single one advantage a Bamboo veneer could have over a quality wooden veneer? Just one!
  #33
Old 08-13-2009, 12:44 PM
micheleoda micheleoda is offline
izarra-yachts
Rep: 10 Posts: 10
Bamboo Products
Actually i live in France and i have a suplier to import and sliced, any size, any lenght , any thickness and larger.
I have diferent suplier's in europe, china and thailand for veneer to 0.6mm to 5mm. About Bamboo, in 1979 we built a 85 ft chineese junk in Canton and bring back to France by The "good hope", so i use bamboo since because i work in Asia (Laos, Thailand, Vietnam, china, phillipines, japan, malaysia and indonesia. For bamboo, we need to know the tricks, now we can use, veneer and thin planks for laminate on traditional way.
I dont beleive about strip plancking
but i'm at 400% for lamination, and epoxy
see bamboo laminate bow, strong and nervous, i like boats like that...
  #34
Old 08-13-2009, 01:05 PM
izarra-yachts
Rep: 10 Posts: 10
www.abamboo.com
about advantage 4mm thick: 7.2$ m2
or 15mm large, 1mm thick, lenght 2m20: 40$ the 100 pieces
i plan to use 3mm thick about advantage, it's a perfect Uni directional wood
if we laminate 0/+45/-45, we something technical, modern, green, not to expensive and excelent for marketing
And about wood, i'm a marine carpenter, and i prefer to use bamboo than cut wood and give money for the F'''''''' Birman military or Cambodgian for their teck wood, if we buy bamboo, we give work to small villages do not have nothing for live except cut wood illegaly or keep protect animals for sell to stupid foreigner's
  #35
Old 08-13-2009, 01:43 PM
apex1
Yes do that!!! And call Peking a small village!!!
Obviously you know what youŽre talking.
  #36
Old 08-13-2009, 02:17 PM
izarra-yachts
Rep: 10 Posts: 10
i dont know pekin but i work in shanguai, and i dont see so much of bamboo plantation around indeed.., and so on
somebody need informations about bamboo and if i'm not too stupid,
it is a forum;
forum is made for friendly relationship.
I'm new on site but you look like to be very polemic on diferent post;
so, or you try to up the discussion or i dont reply you anymore
if you need to be "agressive" for existing (feel alive) it's your problem
but go alone,i dont want to loose time with complexed people
i dont think that you give adriano have any interresting infos and your sens of humor is very limit: Mr AMPEX1
Best regards
MC
  #37
Old 08-13-2009, 02:48 PM
apex1
Well, Mr. marine carpenter you should read a thread before contributing, and especially before contradicting in a offensive way! You would notice how and when I provided substantial information on adrianos questions.
Impressive to see how you differentiate between Chinese and Burmese Dictators, really! But more impressive to see that a shipwright (I assume we should understand "marine carpenter" that way), has absolutely no idea which materials we use in cold moulded boatbuilding! And even more impressive that a shipwright does "not believe" in strip planking. But he feels fine using Bamboo "microfibres" (there is no such material on the market) and Epoxy.
I tell you what:
you are neither a shipwright, nor have you ever worked with any of the material you mentioned!
  #38
Old 08-13-2009, 06:49 PM
aka Terry Haines
Rep: 1682 Posts: 2,810
Where in France is Shanguai? I thought it was a Chinese orchestra.
Dances with Turkeys
  #39
Old 08-13-2009, 07:36 PM
apex1
Was that the "basement" branch of the "Pasadena roof orchestra" Terry?
  #40
Old 08-14-2009, 04:31 AM
izarra-yachts
Rep: 10 Posts: 10
NO PROBLEM
now we are on chinese orchestra,
so, good luck to adriano on this forum, i hope that he find that he want
for the rest, i've many job to do for my shipyard
no time to talk music..
MC
  #41
Old 08-14-2009, 08:26 AM
apex1
Michel
I guess he will not find what he wants! He wants a experts opinion to back up his own prejudice. He did not find that by now, and yours was´nt a experts one.
  #42
Old 08-27-2009, 02:59 PM
Invert Invert is offline
Rep: 10 Posts: 7
I have a question. As teak is rather expensive, what is the possibility of decking with bamboo? From what I can gather, they sell bamboo flooring for about $5-7 sq.ft. which is generally cheaper than pine or oak. Suppose I just wanted it for its looks, meaning it provides no structural integrity. Would somebody recommend something like this? Or is teak still the way to go?
  #43
Old 08-27-2009, 03:11 PM
Luckless Luckless is offline
Rep: 105 Posts: 162
I haven't looked too closely at what is on the market currently, but I know the cheapest bamboo flooring is still a laminate with a wood fiber based bottom layer, which would be completely useless on a boat. One small pin prick in your sealant, and it would swell and split apart.
If you can find thin flooring that is solid bamboo for that price, then I don't see why it wouldn't be an option as a cover layer over plywood. The only thing I would worry about there is how to actually attach it securely.
  #44
Old 08-27-2009, 03:37 PM
kroberts kroberts is offline
Rep: 178 Posts: 279
Invert,
On top of your initial cost of the flooring, add to it the cost of installation and factor in the fact that it won't last nearly as long, so you'll have to replace it sooner.
No matter what flooring you use, figure alongside the cost all of its benefits, how long it lasts, how appropriate it is for the purpose and how many times you'll need to replace something "cheaper" before you get the same life span.
-- Ken
No builds yet. Learning first!
  #45
Old 08-27-2009, 04:37 PM
Rep: 472 Posts: 614
Par and Apex are right. As an old ex-naval carpenter (I began in 1970...) used to almost all the laminated woods systems, with any imaginable kind of glue and fibers common and exotic, I have now a little experience of the subject using wood in boats from 2 meters to 52 meters, from 4 knots to 55 knots.
And as I am also naval engineer, I can say that Par is totally right when he affirms that bamboo is too heavy as core. Plus the problem of the knots which are a solution of continuity when the bamboo is splitted.
I do love Bamboo, excellent material for building houses (look that in Colombia architects are doing with this material), furniture (split or not), pipes and other stuff. You can build excellent houses and light structures in bamboo and I have tried to promote its use and cultivation in Quintana Roo. The strong part is the the very outer shell, or best said the surface skin and structurally it works marvelously as a pipe.
It's a grass so it contains a lot of sugar. It must stay a long time in water to drain these sugars, dried slowly and treated because it rots so easily and catches a lot of bugs. The Japanese even smoke it. There is a very simple system to treat it with borates, but these salts are not good friends with glues...
I have also used the strips and floors made with bamboo, very nice in a house. In a dry house with no bugs. Or you have to buy bamboo heavily treated with some products I wouldn't have near me.
Simply, whatever its qualities, bamboo is not a material for boats.
caulking planks JimHog Wooden Boat Building and Restoration 35 08-09-2011 12:46 AM
Building bamboo kayak (bamboo and recycled wood) from Brazil-Brasilia-DF cadaisdf Boat Design 0 03-11-2009 08:14 PM
Planks, Plywood?? BHOFM Boatbuilding 4 07-30-2008 09:27 PM
Possibility of using new bamboo laminate. hansp77 Materials 40 05-18-2006 08:49 AM
Bamboo Core - What's Wrong With Idea? James Mills Boat Design 11 07-13-2004 11:27 PM
