Old 08-09-2009, 03:58 PM
apex1
Originally Posted by Luckless View Post
I would like to hear the stats on the energy costs in producing carbon fibers vs bamboo fibers. Where are your sources for this?
There are no such statistics as far as I know. Just go through the steps of production and you doŽnt need them.
Old 08-09-2009, 07:07 PM
Luckless Luckless is offline
Rep: 105 Posts: 162
All entries I can find for carbon fiber production uses multiple high temperature cooking stages. Bamboo fiber can be done with a fairly minor mechanical process followed by chemical treatments in reusable baths, and then fairly simple pressings.
Old 08-09-2009, 07:11 PM
apex1
Ja, you are right. And the chemicals are eco friendly and produced by some fresh water and wind???
Old 08-10-2009, 12:39 AM
Rep: 2891 Posts: 8,795
From a physical properties view point bamboo is a crap shoot, unless you can control and harvest the stock, selectively machine and mill it into serviceable stuff, then apply what ever technology you like towards its application in a marine environment.
The problem is the simple physical fact that you can have as much as 100% difference in strength across the culm, plus age and how the material is cut can dramatically affect the physical properties of the material. Without serious controls in place, the best you can ask is it's current usages, which are as a "facing" material.
This coupled with the fact there are over 1,500 different botanical species of bamboo and that it's generally cultivated in areas of the world well known to be less then forthcoming in quality control or honesty in packaging, leaves a fairly dim light cast on bamboo in the foreseeable future.
Old 08-10-2009, 02:54 AM
adriano adriano is offline
Rep: 13 Posts: 15
Luckness,
In communications like this there is a lot of kind missunderstanding.
I never been talking about bamboo fibers but ruther about bamboo planks if ever possible to use, that's all about.
Thanks
Old 08-10-2009, 03:06 AM
I've been talking about bamboo as lumber, not as filler or reinforcement material.
Old 08-10-2009, 09:25 AM
apex1
Me too, and I have described the process to make it a useable plank in another thread some time ago. The result: leave it...............
Adriano,
Luckness,
I have´nt seen a single one! Only the impression that you did not like contradictive results or arguments. Do not ask pro´s when you do´nt like professional answers.
Old 08-10-2009, 10:02 AM
Rep: 13 Posts: 15
Bamboo material
Adriano,
I haveŽnt seen a single one! Only the impression that you did not like contradictive results or arguments. Do not ask proŽs when you doŽnt like professional answers.
Very sorry to give you that impression, may be the missunderstandings, If any, are from my side, I am not a professional like you (as you mentioned in prior forum ?!)
Never been trying to teach anything to anybody but just asked simple questions and " try "to explaining why, hoping to get some opinions, which I am keeping.
I do not think, otherwise, you expect anybody to take as "gold" straight away
whatever is being written here, most of the members are unknown and difficult to figure out their background?! So I take their opinions /suggestions for which I am thankful and continue to search. I do not know what is wrong with this!
All the best
I am done
Old 08-10-2009, 10:54 AM
apex1
[quote=adriano;292361]
Do´nt understand that??
I do not think, otherwise, you expect anybody to take as "gold" straight away whatever is being written here,
Oh no, for sure not.
I´ll give you just another comment on Bamboo to make some points clear:
Bamboo is never a good idea! And the reason is easy to understand. The strongest fibers Bamboo has just under the outer hard skin, but you have to flatten out the round shape and get rid of the nodes. You cut the surface, the reverse side (both very difficult and expensive, due to the shape), then you steam the batten and flatten it by high pressure (50 tonnes are sufficient), and voila... you have a nice, environmental friendly ? and cheap ? material. Strong too (if you are able to skin the surface not deeper than 0,5 mm, but remove all nodes, and the weak and funghi infested inside)! And it will spring back a bit, so you have to laminate two battens back to back anyway! THEN you have a real strong plank, for twice the price of finest Teak. A good idea!?
Regards
Richard
  #25
Old 08-12-2009, 04:52 PM
micheleoda micheleoda is offline
izarra-yachts
Rep: 10 Posts: 10
i believe in bamboo UD veneer
i plan to do a 7 meter sportboat with 3 layers (3mm each) 0°/+45/-45°
of bamboo slices, plus bi-axis fiberglass (inside), + lamination of thin 0.6mm outiside top + mat 400gr
undervaccum, glue by epoxy whith bambou microfiber
i do a trailer boat, So i want a strong and light boat (foam and fiber omegas with one esthetic bamboo UD on top of them)
deck with balsa sandwich/lamination of bamboo veneer
with bamboo or corck for deck, mast and boom with bamboo and fiberglas
UD +45/-45°.
Best regards
MC
  #26
Old 08-12-2009, 05:05 PM
apex1
Yes do that!
Good luck...........................
  #27
Old 08-12-2009, 08:18 PM
ancient kayaker ancient kayaker is online now
aka Terry Haines
Rep: 1682 Posts: 2,816
Bamboo is an excellent structural material that comes as a tube. Sure it's a little lumpy but it has good strength/weight ratio, as is, and is available in a wide range of sizes. It is not easy to cut or bend but it can be done, needs some skill but not much equipment. And that's about it. It's great for stakes, scaffolding and outdoor furniture, and has been made into skin-on-frame boats.
Trying to make a plank out of it is just being silly, or maybe trying to prove a point, or some other doomed thing. Whatever you try to do with it, the further you go from its natural condition the harder the task will become and the less useful the product is likely to be. Unlike timber, the properties of bamboo change rapidly and continually as you penetrate the surface. So you can't make it into ply for a start and whatever else you do with it is going to take a heap of machinery and chemicals.
Dances with Turkeys
  #28
Old 08-12-2009, 11:46 PM
Actually, you can make planks from bamboo folks. As I mentioned there are a lot of versions of bamboo, some are huge and easily cut into planks.
  #29
Old 08-13-2009, 04:26 AM
Rep: 13 Posts: 15
Thanks
I appreciate all further notes on Bamboo.
Indeed I was starting the whole issue based on the fact first that fairly accetable thickness are available from the so called Giant species like Moso etc. and then deal with next step or whatever problem is to be faced.
Adriano
  #30
Old 08-13-2009, 04:45 AM
Again as a core, it offers little benefit in epoxy strip plank construction. As a veneer it has possibilities.
caulking planks JimHog Wooden Boat Building and Restoration 35 08-09-2011 12:46 AM
Building bamboo kayak (bamboo and recycled wood) from Brazil-Brasilia-DF cadaisdf Boat Design 0 03-11-2009 08:14 PM
Planks, Plywood?? BHOFM Boatbuilding 4 07-30-2008 09:27 PM
Possibility of using new bamboo laminate. hansp77 Materials 40 05-18-2006 08:49 AM
Bamboo Core - What's Wrong With Idea? James Mills Boat Design 11 07-13-2004 11:27 PM
