Old 11-30-2011, 12:39 PM
Boston's Avatar
Boston Boston is offline
Rep: 1457 Posts: 3,355
Bambo fiber as a glass substute
stumbled on this site selling oriented bambo fiber cloth as a substitute for fiberglass on surfboards.
thought it might be worthy of discussion here, eventually my own build might just end up with a coat of glass on it somewhere and I'm just looking for alternatives. Gotta do the eco friendly thing you know, although this stuff, unlike the ecopoxy peanut based epoxy this bamboo stuff is waaaaaaaaayyyyyy expensive.
http://greenlightsurfsupply.com/bamboo-fiberglass.aspx
I am skeptical of the deniers diatribe
Old 11-30-2011, 10:06 PM
Rep: 1493 Posts: 7,447
If you want to go ecofriendly, recycle an old rowing boat. The fibers have little or not impact on the environment. It is the resin, hardener, fairing compound and solvents that do.
Old 12-01-2011, 12:54 AM
PAR PAR is online now
Rep: 3125 Posts: 9,402
Look up the tensile and compressive strengths of Bamboo fibers, then compare this to 'glass and you'll see why it's not taking the industry by storm Dan.
Old 12-01-2011, 01:16 AM
Boston's Avatar
I think its main advantage is its flexibility, but its price and its weight raises some questions. I just thought I'd throw it out there and see what folks might have used it and what they thought of it.
Its something like 1.5x heavier than glass of the same strength, so a 6 oz of bamboo is about as strong as 4 oz of glass. But its got huge flexibility before it fails. Seems like as a dressing for say strip planking it would have some advantages.
I don't know I was just throwing it out there. Might have applications in the boating world might not
Old 12-01-2011, 03:50 AM
MechaNik MechaNik is offline
Rep: 46 Posts: 92
Sounds like another half attempt at a Green concept. Focus on one aspect and ignore every thing else.......
If the fiber hasn't got the strength you possibly using more epoxy than needed which is the real issue?
Old 12-01-2011, 07:02 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,055
It's wooden thou but anyway..
Old 12-01-2011, 07:41 AM
Considering the density difference, the laminate will be about three times thicker. That is a lot more goo and I'd say less green.
Old 12-01-2011, 03:05 PM
The green thing aside, bamboo has an elongation issue with most resin systems. You can use one of the modified epoxies (like G-Flex), so your fibers fail about the same time as the resin, but you take a huge stiffness and strength hit when you play with reinforcements like this in regard to a hull shell.
Old 12-01-2011, 03:50 PM
Boston's Avatar
and the search continues
the majority of the issues with going "green" can are resolved for me by using the peanut based epoxy.
If I used the bamboo cloth, and its expense is going to be just one of the issues involved, I'd be looking to it as a dressing for the outside of a wood build. Its stiffness wouldn't be as much of an issue as its weight, which is a definite issue. For less money I could go with kevlar except that I'm a small fish in a big pond and cant really afford kevlar.
Old 12-02-2011, 07:25 AM
You can build a wooden boat fastened with trunnels and lashings.
Old 12-02-2011, 02:22 PM
Popsicle sticks and the sticky remains of the lollypop?
Old 12-30-2011, 12:28 PM
yellowcat yellowcat is offline
Rep: 15 Posts: 32
i was also considering bambo (seems ecolo for its regrowth) , but it seems that okoume ply from china is way less expensive and does the job. But i am looking at Innegra hybrids with glass. I am also looking at the "skin" designs, no more foam "fatigue" . This is a new way of thinking for me, but perhaps the outerskin can be thin-ply for the fairness of the outer paint job. Looking at Alexseal paint system, sexy stuff.
This opens the mind to an hovercraft catamaran possibility, in shallows and hightides seems so practical. Compromise compromise ...
We use carbon fibers on a regular basis, it is light and stiff, but ...
Old 12-30-2011, 01:21 PM
Boston's Avatar
you might avoid Chinese ply, it gets a pretty bad rap by most of these guys
Old 12-30-2011, 01:56 PM
Rep: 670 Posts: 2,457
Speaking of Chinese ply...I recently bought a sheet of no name , 12mm "Marine" okume, chinese stuff from a local lumber supply. 100 euro, not cheap. The ply was for bilge storage boxes so I wasn't to concerned about quality. Well I built the boxes and left the cutoff scraps of 12mm outside on the shipyard hardtop , under a work bench, to be used in future as clamping pads. It rained for a few days and those rainwater wet scraps of 12mm chinese marine ply delaminated before my eyes !!!!! I could separate the plys with my fingers. BEWARE
Old 12-30-2011, 01:57 PM
Petros Petros is offline
Rep: 889 Posts: 1,005
The measure of the resources consumed is the cost. If it costs more to manufacture than it is not "green". Fiberglass is not even as stiff as wood, so using something even less stiff than fiberglass means you will not be adding any strength, only a resin and fiber "cover".
Bamboo has little rot resistance compared to some types of wood, so any moisture intrusion would soon rot. If the whole assembly does not last as long as fiberglass, than is also indicates it is not a "green" way to build. Costs more (uses more resources) and does not last as long is NOT green.
Making something more durable that lasts longer is more green than using a labor intensive "natural" fiber that will break down too fast.
Do not get suckered into spending more money on infirior materials thinking you are doing something good for the environment. The "greenest" thing you can do, as Gonzo pointed out, is restore an old boat that was otherwise going to the land fill. Even greener is to stay at home and watch radio, you use far fewer resources than building or using a boat.
general cargo fiber glass sorooshghaderi Boat Design 0 04-22-2009 10:09 AM
18 m fiber glass hull for sale (new) Nabil Marketplace 0 07-12-2008 04:08 AM
cold moulding vs fiber glass nautical Wooden Boat Building and Restoration 21 05-13-2007 10:48 AM
Weight of fiber glass jfblouin Fiberglass and Composite Boat Building 10 07-14-2005 10:30 AM
