Old 02-18-2006, 05:26 PM
jbassion jbassion is offline
Semi-Pro
Rep: 10 Posts: 63
Awlgrip or Sterling?
I have used AwlGrip with good results both roll and tip and spray. The local coating supplier is trying to sell me on Sterling for my current project, a 38' sailboat. Has anyone had any experiance with Sterling? I would like some feedback before I mortage the house to buy paint.
Old 02-18-2006, 05:38 PM
Oyster Oyster is offline
Rep: 90 Posts: 233
I have used a bunch of Sterling. The reason for using it, was during the many formulas of Awlquip and problems with bubbles and fisheyes and curing problems, and the use of Awlquip being primarily sprayed, I did not have the luxuary of papering off huge amounts of parts to do and redo sections of larger hulls when work was an on going progress of total refits. I also did not have the advantage of redoing paints on small sections of a boat, in open areas that would create an issue with overspray when spraying a small area or repair. I found that Sterling worked wonderfull and in my particular I also have a skiff that has it on it, that is now 8 years old, and still easy to clean and still holding its shine.
I still use the primers from awlquip when I need two part paints, but will order in more Sterling to redo my own skiff, since its a cold moulded skiff with glass skin. Thats the building schedule for my flats or shallow water skiff.
FWIW, Merritt Boat Works in Pompano Beach used Sterling on almost all of their sportfishing hulls, that were in for routine upgrades and ongoing maintainance , mostly all brushed in the water.
Old 02-18-2006, 09:17 PM
Rep: 309 Posts: 589
You can brush both Awlgrip and Sterling with very good results. In fact I would dare to say a skilled roll tip team can outfinish even a good spray guy. The only things I noticed in using them both:
The Awlgrip topcoats seemed to have more solids than the Sterling. I got better coverage out of the Awlgrip
The colors from Sterling were a lot nicer colors for traditional boats. A little less racy and more like the old colors we used to know. They are still very glossy if you choose to finish it that way.
I'm with Oyster on the primers ,I still like Awlgrips primers better.
Old 02-18-2006, 09:37 PM
Rep: 90 Posts: 233
A short caviat to brushing is the thinners for brushing Sterlings, in my opinion is better. Thats just my observation. I will even use the awlquip primer thinners in the topcoats of awlquip in lieu of the brushing thinners suggested by Awlquip.
Old 02-19-2006, 09:19 AM
Semi-Pro
Rep: 10 Posts: 63
Thanks for your input. Sterling is sounding better all the time. The part I like the best is that it can be repaired. I have heard the the flow is better in Srerling so that it rolls and tips with better results. It took me 4 times around on my old 27' with Awlgrip until I got a good finish, sanding between each coat. I havent decided if I am going to spray my 38'. Propably will. Because I have to do the deck also - a real pain to roll and tip well. The only unknown I have is the gloss. Is it as good as Awlgrip?
Old 02-20-2006, 12:37 AM
Rep: 2891 Posts: 8,789
Hey, big guy, still fooling around with boats? You learn hard don't you. Kidding aside, you'll have good performance with Sterling. Many shops in this area use the stuff, because of it's forgiving nature.
Old 02-20-2006, 06:30 AM
Semi-Pro
Rep: 10 Posts: 63
Morn'n Par
By the time I finish this one I'll be ready to work for you!
I guess I'll go with the flow and spray Sterling over a rolled and tiped (for thicker build) Awlgrip Primer. Know where to get a good price?
Old 05-31-2006, 01:03 PM
JR-Shine JR-Shine is offline
SHINE
Rep: 50 Posts: 282
We had a representative from Sterling come to our office/shop and give a demonstration, which I turned into a tutorial on rolling and tipping Sterling topcoat. Here you go.....
http://www.boatbuildercentral.com/he...g_roll_tip.htm
Old 06-01-2006, 07:37 PM
Semi-Pro
Rep: 10 Posts: 63
Nice wrte-up Shine - good pictures
Couple of questions. I am painting a 38' sailboat. I have all ready sanded the old paint off down to gel. Do I still need to use the heavy primer? I didn't buy stock in 3M. Your write-up didn't mention the recommended numper of finish coats. Awl-grip is 4 coats. I'm assuming Sterling would be the same. How do you figure the Sq. Ft. of the hull? And the $64,000.00 question---How do you get a straight boot line!!
Old 06-02-2006, 09:05 AM
SHINE
Rep: 50 Posts: 282
Boot stripe - use tape and follow the water line - hopefully you didnt sand it off
The high build primer (epoxy) is what will have the strongest bond to the gelcoat/glass - it sand easy if you go after it within a couple days of application. I you wait a couple weeks you will use a lot more paper. If you are going to wait a couple weeks to sand then maybe you go long on 3M puts
Coverage will be the same as Awlgrip, darker colors sometimes take more coats to get it even.
Joel
Old 06-02-2006, 04:21 PM
buckknekkid's Avatar
buckknekkid buckknekkid is offline
Rep: 37 Posts: 345
Speaking of 3M , scrubbies works best on non skid
Can anyone spare any gas today for a hamburger on Friday ???
Awlgrip vs. Awlcraft 2000 JoseNoy Open Discussion: All Things Boats & Boating 0 09-05-2005 02:12 PM
Awlgrip painting/fairing crew required DGreenwood Services & Employment 6 06-21-2005 12:49 PM
I need HELP! AWLGRIP PAINT OVER GELCOAT chkmahow Materials 2 06-27-2004 12:14 AM
sterling 38 open fish stepp hull russell erickso Powerboats 17 04-19-2002 11:01 PM
