Old 06-01-2007, 09:34 PM
kerosene kerosene is offline
Rep: 175 Posts: 420
aspen as boat building wood
Hello,
I would like to hear if anyone has heard of use of aspen in boatbuilding. It seems reather light - pretty strong for its density and plentiful in Finland where I am from and where I will end up.
I know it dulls tools pretty bad - people say that it sucks up sand - I gues it idoes have high mineral content or something.
I was thinking of finding a use for it mire like a core material then surface. Coldmolding maybe 3-4 layers and using aspen in the midle - how does taht sound. I doubt that its very rot resistant - back home its used iin sauna seating as it insulates pretty well. At least in that wet/hot environment it seems to hold pretty well - bare wood that is.
numbers:
a) Density, g/cc b) Density, lbs/cu.ft. c) Modulus of rupture, air dry kg/sq.mm. d) Modulus of elasticity, air dry,
Aspen Populus tremuloides
a) 0.401 b) 25.03 c) 6.04 d) 838.
compare with cedar for example:
Cedar, eastern red Juniperus virginiana
a) 0.492 b) 30.72 c) 6.07 d) 612
Cedar, northern white Thuja occidentalis
a) 0.315 b) 19.67 c) 4.56 d) 568
Cedar, southern white Chamaecyparis thvoides
a) 0.352 b) 21.98 c) 4.77 d) 655
more from http://www.genetrade.net/main/specinfo/aspen.html
"Natural Durability
The heartwood is reported to have very little natural resistance to decay in contact with the ground. Standing trees and logs are vulnerable to attack by forest longhorn beetles, and trees may be attacked by wood-boring caterpillars. The sapwood is reported to be seldom attacked by powder-post beetles.
Blunting Effect
The wood is reported to dull cutting edges slightly.
Cutting Resistance
Saws tend to bind occasionally during conversion, but cross-cutting and narrow bandsawing operations are reported to be satisfactory.
Planing
Aspen tends to be woolly and requires very sharp and thin cutting angles for best results in planing and other machining operations. Cutters with reduced sharpness angle have also been recommended.
Gluing
Gluing qualities are reported to be very good.
Steam Bending
Aspen is reported to be unsuitable for solid bending since it tends to buckle severely on the concave face. Strapping and end-pressure devices are reported to do very little to improve bending properties."
The last one seems to pose a problem the rest seems pretty good.
Old 06-02-2007, 08:10 AM
nero nero is offline
Rep: 112 Posts: 624
Might work well above the water line.
Old 06-02-2007, 08:35 AM
TerryKing's Avatar
TerryKing TerryKing is offline
On the Red Sea!
Rep: 278 Posts: 581
Location: King Abdullah University of Science & Technology - Near Jeddah, Saudi Arabia
Forest Service Handbook
Take a look at:
http://www.boatdesign.net/wiki/Mater...t_Construction
Nothing specific to Aspen right there, but the US Forest Service Wood Handbook which is linked there will have info...
Regards, Terry King ...On the Red Sea at KAUST
Boat Building cut thread wood screws !!! luke bronco Marketplace 4 09-28-2008 11:14 PM
Building Spray rail... What wood?? Tiara3100 Materials 4 10-24-2006 08:38 PM
Boat Building wood available in PACNW Ike Materials 6 10-10-2006 09:52 PM
Building a wood rudder Eagle Boats Wooden Boat Building and Restoration 1 09-01-2006 09:38 AM
Lightweight building with wood? T Sailor Boat Design 8 05-01-2006 02:22 AM
