Old 02-01-2005, 07:42 PM
Corpus Skipper's Avatar
Corpus Skipper Corpus Skipper is offline
Hopeless Boataholic
Rep: 173 Posts: 604
I always use at least 6 coats of mold release, and give the mold a good cleaning with mold cleaner first. I don't let it sit, wax then layup. Hope this helps.
Craig Cavanaugh
Silver King Custom Marine
No shoes, no shirt, no problem!
Old 02-01-2005, 10:15 PM
wet-foot wet-foot is offline
Rep: 10 Posts: 175
So you clean the mold then wax and polish 6 coats one after another - then do the lay-up?
Old 02-02-2005, 09:21 PM
Hopeless Boataholic
Rep: 173 Posts: 604
Yup.
Craig Cavanaugh
Old 02-02-2005, 11:53 PM
Rep: 10 Posts: 175
Gelcoat
Corpus Skipper,
Your posts have certainly helped point me in the right direction, thanks so much. Make sure and let us all know when you get those new boats ready for market. Would enjoy checking them out on your website!!!!!!! Best of luck with your boat building business.
Old 02-03-2005, 10:44 PM
Hopeless Boataholic
Rep: 173 Posts: 604
Thanks, and I'll try to get some pictures up soon.
Craig Cavanaugh
Old 07-17-2007, 03:13 PM
Skip M. Skip M. is offline
Brushable Gelcoat
Brushable Gel Coat was mentioned early on in this thread. I know this discussion was some time ago, BUT...Where would I find brushable gel coat. What product name should I be looking for?
Old 07-17-2007, 03:19 PM
Hopeless Boataholic
Rep: 173 Posts: 604
There is an additive, I believe, that makes gelcoat "brushable". You will still have a considerable amount of sanding and polishing to do to achieve a smooth, glossy finish. I've found that short of spraying, rolling gelcoat on achieves the best results. Nothing will make it perfect unless it's laid up in a polished mold.
Craig Cavanaugh
Old 07-26-2007, 09:25 PM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
If this was a new mold 4 coats aren't enough and you need to wait between coats. Did you rewax it each time, or just before the first part?
You can use PVA on the mold for a more reliable release, but the surface may not be as good when you demold the part, so you may need to sand and buff it to get a good gloss.
Adding some Duratech clear will help it level when brushing.
Old 12-10-2011, 09:26 PM
redfox redfox is offline
Rep: 10 Posts: 2
Hello Corpus Skipper !
I note that you answered a question that I have at the moment about gelcoat rollers back in 01-26-2005.
I am currently doing a gelcoat repair job on a sailboat rudder, I have applied two coats so far with reasonable success, using a new roller each time.
I'm using gelcoat thinned with acetone and notice that I get thin elastic type strings coming off the roller about 2 - 3 minutes into the rolling job. I suspect this is the roller material breaking down and "stringing out". I think my roller material is polyester fibre.
You mentioned a "white with an orange spiral stripe really plush" roller from Home Depot that could be washed with acetone.
Can you give me any more detail ? Like type of roller material or Home Depot part number ?
Regards
Lorne Dudley
Kingston, Ontario
  #25
Old 12-10-2011, 09:41 PM
Hopeless Boataholic
Rep: 173 Posts: 604
All I can tell you is that they are four inch rollers, and come two to a package. Haven't bought any in a couple years since the economy cratered and my repair business dried up. They will leave a little "fuzz" at first, but they don't disintegrate like others will. Sorry I can't be more help.
Craig Cavanaugh
  #26
Old 12-10-2011, 11:37 PM
Rep: 10 Posts: 2
Hello Craig !
Thanks for the quick reply. I saw something at Home Depot with an orange spiral about 4 " long. (about 1 " dia. I think).
I can give those a try by soaking in acetone and see if they disintegrate.
Someone on another forum is advising that I should not be using acetone to thin the gelcoat. Do you have any advice on that topic ? Is there any other thinner that would work better ?
I am finding that my gelcoat lumps up quickly if I do not thin it a bit.
I have two layers on so far, and other than the roller breaking down about 2 minutes into the process, I'm getting good results. I can complete the application in about two minutes. (30" x 9" x 2" rudder area).
Regards
Lorne
  #27
Old 12-11-2011, 10:48 AM
Hopeless Boataholic
Rep: 173 Posts: 604
I only thinned gelcoat when spraying with a paint gun. Acetone is the right stuff to use, but only a little. By the way, it's the styrene in the gelcoat that eats lesser rollers. You will not get a perfectly smooth, paint like finish with gelcoat. It must be sanded and polished to be smooth and shiny, so it's best to lay it on thick if that's what you want. If you're happy with your results so far, then keep on keepin' on.
Craig Cavanaugh
Spraying gelcoat over gelcoat alexhiguera Fiberglass and Composite Boat Building 9 08-26-2005 10:09 PM
milky patches in clear gel coat still afloat Fiberglass and Composite Boat Building 3 07-22-2005 03:29 PM
Gelcoat project on 71 Shark LtsGo4ARide Fiberglass and Composite Boat Building 4 07-03-2005 10:02 AM
Clear Gelcoat Dawgfish71 Materials 8 04-05-2005 12:33 AM
Gelcoat over Epoxy wet-foot Boat Design 9 08-16-2004 06:58 PM
