Old 02-16-2006, 09:51 AM
Bob S. Bob S. is offline
Rep: 21 Posts: 40
Anyone using SS staples?
I was curious if narrow crown ss wire staples (up to 1.5" long) would be appropriate for wood boat projects? Not sure of the alloy used (I believe they are #316). Pnuematic stapling would be very handy for stitching things together in conjunction with epoxy and other adhesives to eliminate a lot of clamping.
Old 02-17-2006, 04:50 PM
Rep: 324 Posts: 591
Monel is better and sythetic ones are even better. The big problem with synthetic ones is the pneumatic stapler that is required to drive them is quite expensive. No need to remove them...you can sand them right off.
In my experience far superior for boatbuilding purposes once you are set up.
http://www.raptornails.com/raptornails.html
Old 02-17-2006, 05:09 PM
DanishBagger's Avatar
DanishBagger DanishBagger is offline
Never Again
Rep: 523 Posts: 1,543
Originally Posted by DGreenwood
Oh, those are nice
Old 02-17-2006, 08:48 PM
Rep: 324 Posts: 591
Yeah...definitely. In the old days we tried al kinds of ways to pulll those G*# D&#n staples out of cold molding. This way you just leave them.
I have seen where guys have left the stainless staples in and glassed over them thinking that the glass and epoxy would protect them. Some years later you could see lumps under the skin where the staples were corroding.
Old 02-17-2006, 10:37 PM
Rep: 21 Posts: 40
That is interesting that the ss staples corroded and caused problems. I wonder if they were #304 alloy and/or would #316 staples also get punky? Thanks for the link to those plastic staples. They don't seem to have any way to order them or the nailers online or any pricing. Guess they want you to call. It appears that a standard coil nailer will handle some of the nails however.
Old 02-17-2006, 10:51 PM
Rep: 324 Posts: 591
Some of the nails seem to work OK and are great for strip planking but I would not recommend trying to use the staples without their recommended tool.
The boat that had the problem with SS did not have the interior side sealed. (not to be confused with ceiled, another thing altogether) Hadit been glassed or at least epoxy coated the problem probably would not have occured.
Old 02-17-2006, 11:34 PM
MRRPM MRRPM is offline
Rep: 10 Posts: 8
I am not sure on this but>> I think if the stapples corode the are stainless but a lower grade lik 401 or 302 as for the structural integurity. They are yused a lot in construction of building in damp areas.
I am only putting my 1/2 cense innot 2 cense
Robert
