| Anyone know where I can find Window Seal Rubber?? I have been slowly been fixing up my 1981 20ft Wilson Boat. It is about time to replace the window rubber that seals the windows in. I have tried many boat builders in my area and they are un-willing to give me any info. The boat is made out of 1/2 inch fiberglass plywood and 1/4 pane auto glass. I have seen some boats with the 1 inch rubber seals which look rather nice. I know I can get custom aluminum windows, but I don't want them I just want the rubber seal gasket.. Thank in advance, Larry |
| I would go to your local glass shop that replaces auto windshield and check with them. Make sure the product is waterproof. |
| Rasoninc, Yes, I did that already and no one carries it. What is up with that?? The problem is the 1/2 fiberglass to plywood cabin to 1/4 inch glass. |
| Delta Marine Industries, Seattle, WA.. Ask for Ed Vacura or Chuck Albertson. They will send you to the right place. I think the manufacturer is in Oregon but I couldn't come up with it. Sorry. |
| Hamilton Marine, Searsport, Maine |
| and vetus.com not to forget. |
| I was trying to find him a local manufacturerer. I actually bought some custom white (I feel that black looks like 'coon eyes) from a plant in Oregon at one time. When Delta used to make charter boats, Goodrich or Goodyear or somebody such in Oregon made the rubber. |
| Mark, thanks so much. Ya, I was looking for a online place also would like to find a American manufacturer. I know I can order from england at: http://www.sealsdirect.co.uk/bbCMS/s...artmentId=4#27 Not sure if I can get the same thing here in the U.S.A. |
| Any new post?? |
| Add automotive manufacturers and suppliers to your list. Many of those rubbers profiles are available, canoppy manufacturers also uses it.
| Quote: ![]() |
| http://www.technologylk.com/_AS1707/...1-4-Glass.html OK found a place that has it all.. You can get tools and rubber. http://www.technologylk.com/ Manufacture is USA is http://www.crlaurence.com/ |
| Mokaction and Apex1, The ruegg site only shows the size up to 10 mm for the plywood side, 3 mm too narrow. Sorry. |
CRL Two-Piece Self-Sealing Universal Weatherstrip 15/32" to 17/32" Panel - 3/16" to 1/4" Glass Glass Thickness: .1875 to .250 in (4.8 to 6.4 mm) Panel Thickness: .469 to .532 in (12.0 to 13.6 mm) Overall Width x Height: 1.0 in (25.4 mm) x 1.1875 in (30.2 mm) Length: 50 ft (15.2 m) the glass on my boat is 1/4 inch and the cabin walls are 1/2 inch.. Perfect fit.. ![]() Also needed 40 feet to do the job.. always nice to have some extra.. Larry |
| Transom Seal - Where are you? | Elmer Bowman | Sterndrives | 1 | 08-07-2009 06:30 AM |
| when to seal a hull | michael15725 | Boat Design | 7 | 05-24-2008 09:29 AM |
| transom seal | rsix | Sterndrives | 3 | 03-08-2008 10:25 PM |
| Seam Seal | justplanecrazy | Wooden Boat Building and Restoration | 14 | 10-12-2006 08:44 AM |
| polyurethane rubber | Materials | 1 | 06-29-2002 10:20 PM | |
