Old 08-20-2002, 08:48 PM
Rocinante Rocinante is offline
Rep: 10 Posts: 4
Any luck with powder coating?
Has anyone on this forum used powder coating, either below the water line or above? Seems to have a number of advantages over paint, but I'm curious about its performance in a marine environment. How does it compare to galvanizing and linear urethane in terms of wear and cost?
Thanks,
Scott
Old 08-30-2002, 02:16 PM
JORGE LANG JORGE LANG is offline
Rep: 60 Posts: 21
We offer white powdercoating as a finish on exhaust systems we fabricate. There have not been any problems with the finish. Of course, this is in the engine room and not as exposed as it would be to the elements as if it were sitting on the deck somewhere. Attached is a picture of a powder coated elbow. I hope this helps.
JORGE LANG
DEANGELO MARINE EXHAUST
Old 08-30-2002, 04:15 PM
Rep: 10 Posts: 4
Thanks for the reply, that's a good-looking part! I was talking about the outside of the boat, you're right. The benefits of powder coating on parts like you produce are so well known, I'm kind of surprised I don't see it more on other parts of the boat. I think most outboards and out-drives come powder coated from the factory though, which may answer my own question (perhaps someone can confirm this).
Scott
Old 10-13-2002, 07:57 AM
fishboat fishboat is offline
Registered
Rep: 10 Posts: 25
This thread is a bit old, but if you're still interested....
Take a look at the larger center console boats down in Florida. A number of them are using powder coating for T-tops. Also look to the custom fabricators of T-tops, railings...
http://adcache.boattraderonline.com/6/0/4/34778204.htm
The key to exterior duability in a powder coating is to look for an acrylic-based resin binder. Some polyester based powder paints are good outside, but acrylic is typically the best. Acrylic powders have been used on automobile wheel covers and under the hood parts for a number of years. Road salt should be a reasonable test for holding up to saltwater exposure (actually an extended salt-spray test is one of the criteria that is used in selecting coating materials for the auto industry).
Old 11-26-2004, 09:41 AM
powderman powderman is offline
powder coating
We use powder coating above and below the waterline. Almost everything is two-coated though using an epoxy primer and a marine grade color topcoat after a chemical treatment to improve adhesion. (Acrylics have excellent weatherability but don't have the chip resistance of polyesters.) We've done T-tops, leaning posts, rails, rub rails, ladders and brackets of all kinds.
We're using a Dupont non-stick on props. (This is the black stuff found on frying pans.) It is in the experimental stage but we're hoping to make it tough for marine organisms to hang on. This stuff is also very abrasion and corrosion resistant.
We're also using anti-microbial coatings on shafts, trim-tabs and struts. This is also experimental but it suppresses the growth of bacteria, algae, fungus, mold, and mildew in many other applications.
deck coating skiffish Materials 35 01-24-2009 11:35 PM
Cement wash coating for steel protection MikeJohns Metal Boat Building 30 10-08-2008 06:39 PM
Bondo hull coating EASI54 Metal Boat Building 15 09-25-2005 09:32 AM
Polyester Resin Floor Coating FishTales Materials 4 09-26-2004 10:45 PM
Coating Steel Bob Smalser Boatbuilding 6 11-30-2003 12:37 AM
