Old 05-26-2005, 10:11 AM
WAHiggins WAHiggins is offline
Aluminum vs. Galvanized Steel
Ignoring any cost difference, which is the better material for a boat trailer in salt water, aluminum or galvanized steel? Is there any concern with galvanic
corrosion between aluminum and stainless steel fasteners?
Old 05-26-2005, 09:35 PM
PowerTech PowerTech is offline
Rep: 4 Posts: 183
aluminum is the way to go.no trouble at all seem to last forever.these folks make a great trailer.http://floaton.com/
Old 05-26-2005, 10:17 PM
cyclops cyclops is offline
Rep: 29 Posts: 1,059
Aluminum, other metals, not great coatings on the metals and lots of humidity year round? Pick very carefully. Wash the tight spots on the trailer with enough fresh water to remove weeds and the salt.
Old 05-27-2005, 08:58 PM
Arrowmarine Arrowmarine is offline
Member
Rep: 10 Posts: 107
Aluminum, Definately.
My only advice is:
You didnt say what kind of boat or how big, but take care that you know what you are doing or can ask somebody who does. I dont know how many aluminum welders I know(myself included) that have figured "with my years of experience I can build anything out of aluminum. Dont know how many aluminum projects I have seen fail cuz they dont really understand the engineering of the project and the stresses that are put on them.
I have a hanful of pics from an all aluminum trailer that was underneath a Boston Whaler that I did some work on. Its all bolted, no welding at all. Prolly what I would do if I was going to build one. If you would like, I can send them to you.
Anyway, all I'm saying is do your homework if you need to.
Peace, Joey
Old 05-27-2005, 09:11 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Aluminum and good hot-dipped galvanized are both good for trailers. Both beat painted steel by far. Aluminum would get my pick; it's about as good as you can get for corrosion resistance. And for sure heed Arrow/Joey's advice on making sure it's professionally done- aluminum welding is not for amateurs.
As for corrosion: Galvanic corrosion is not an issue on trailers- PROVIDED THAT you hose it down with fresh water after hauling it out. Ideally you should flush the motor and wash the trailer down immediately after hauling the boat out, before it has a chance to dry off. If you don't flush and rinse your rig, you will of course get corrosion on both trailer and boat regardless of your choice of metals.
Old 05-28-2005, 07:43 PM
nevd nevd is offline
Rep: 10 Posts: 99
Aluminium trailer
Hello Arrowmarine,
I would appreciate seeing your photos of the fully bolted trailer as I also beleive that is the way to handle aluminium in trailers, particularly if they are to be used on poor roads.
Thanks
nevd
Old 06-02-2005, 01:32 AM
Member
Rep: 10 Posts: 107
Aluminum Trailer Pics
I thought I had some better close ups, but here you go, Hope they help.
Joey
Aluminum vs. Galvanized Steel-dscf0013.jpg  Aluminum vs. Galvanized Steel-dscf0019.jpg  Aluminum vs. Galvanized Steel-dscf0014.jpg
Stainless steel / Aluminum hendrikus Boatbuilding 5 06-30-2006 07:40 PM
Steel and Aluminum Boatbuilder, Pac.N.W. SolomonGrundy Metal Boat Building 1 03-21-2005 09:33 PM
Overuse of cathodic protection on aluminum or steel hulls Thunderhead19 Boat Design 6 02-28-2005 07:20 AM
shroud attachment...steel or aluminum zoomee Sailboats 1 10-22-2004 10:45 AM
Looking for job with steel and aluminum Boat builder Services & Employment 0 03-26-2002 10:33 AM
