| aluminum and stainless steel together in sea. Hi all, I'm building a piece that will stay in sea water and I need to have a piece of stainless stell 316 and a piece of anodized aluminum piece in contact. Is that possible or will have for sure some electrolysis that will corrode the aluminum? so far I have done samples using some 100% aluminum and it does corrode very quick.. I was thinking about using some Aluminum A-G10SBe (i.e. with about 10% magnesium, some Silicium and Beryllium) with some Cadmiun anodization does anyone have had experience with this before? does it work? and if not, what type of aluminum would you recommand instead of the one I picked? note that the aluminum piece is a casted piece so I must use a "casting friendly" aluminum. thanks a lot in advance for any help, Damien. |
| can you isolate them, like with a gasket of engineering plastic, or sleeved screws. or how zakkly are they attached? |
| Hi, thanks a lot for your reply, well no I can not really, the aluminum piece has two holes in it where a stainless steel rod is jammed in and then a piece of stainless steel is rotating around that rod. do you think there is no way it is going to not electrolyse and corrode? |
__________________ Best, Charlie |
| Stainless steel / Aluminum | hendrikus | Boatbuilding | 5 | 06-30-2006 06:40 PM |
| Scud or Warwick 24 - Wooden boat with stainless steel and aluminum lift keel ! | boony | Boatbuilding | 3 | 06-08-2006 10:01 PM |
| stainless steel mast? | turedogan | Sailboats | 21 | 06-05-2006 12:01 PM |
| Bending Stainless Steel | mojounwin | Metal Boat Building | 4 | 10-25-2005 09:25 PM |
| Stainless Steel hull? | trouty | Boat Design | 3 | 11-18-2002 02:57 AM |
