| Aluminium prices that high ? Being new to this forum, i'll start with a short Hello! ![]() I might want to build myself an aluminium boat (sometime in the near future). So I was looking for prices on 'marine-grade' aluminium like 5052, 5083 etc. The few prices I found are something like this; -Aluminium 5083 plate, (various length/width), thickness 4mm/5mm (.16/.19 inch), aprox 15 EURO per kilo (~$19). According to my calculations, the minimum for an open 5metres/16feet (fishing)boat, would be around 600 kilo of plate. That's before cutting, so including waste material. Well let's see, that makes 600 * 15 euro = 9000 euro (~11500 USdollar) ... minimum And then there are all the other costs ... Is it really this expensive to build with aluminium ![]() |
| Metal prices All metals are way up right now. Up until 6 months ago aluminum had been the bargain. We got hit with 2 20% increases so far this year. Copper has quadrupled in the last 18 months, and stainless is also way up. They're blaming it on China and fuel prices. It's a great time to be collecting scrap! |
| I had a visitor from a small boatbuilding company, building workboats in aluminium. He said they paid approx one euro per kg... I have to call him and see if I understood it right :-) |
| @snal Indeed A recent article from a Dutch newspaper; "There's an explosion in copper thefts [..] Especially lightning protectors are popular, these contain 100 - 500 Kg of copperwire. This makes 500 - 2500 euro on the black market. An estimate is that 30 - 50 of those systems dissapear on a weekly base, in earlier years the score was around 5 a year." @Raggi_Thor Well that sounds like a great price to me ![]() I'm very curious about which kind of aluminium he uses and where his supplier is located. |
| Sheet can be bought at under 4 euros a kilo anywhere in EU if you a business, At least we can and we only by 50 tons a year. Standard profiles are mainly under 4 euros but some tubes fetch as much as 6,5 euros a kilo. Individuals can by most grades at 6-7 Euros a kilo from retailers. A year ago September we paid 3,12 to for sheet 5083 and 3,37 for 6082 in june 2005 we managed to get under 3 Euros ocaisionaly. |
| @Richard Hillsid Thanks! that's some usefull info. I Just received an offer on 5083 sheet for 4 - 4.5 Euro a kilo. So that's not bad when I read your reply. My earlier calculations for 600Kg bruto makes now 2400 - 2700 Euro instead of 9000 ![]() |
| Good for you winters AL is a good chose. |
| The actual price of 5083 is Euro 3,70 per kg ex. For special sizes, prices may come higher, above Euro 4,00. Prices are basen on quantities above 2000 kgs. |
| @D'ARTOIS Great! I see you are from NL too. Do you have tips on where to go for 'actual prices' etc. ? |
| I can give you the NAW details of my supplier and you may ask him for a quotation: ALULAND, tel.: 078-6230020 - fax: 6230040 - they are supplied by Corus and Garfield Aluminium Industries e-mail: info@aluland.com |
| Ok thanks alot ![]() |
| Ex VAT |
| alum. prices I recently was quoted $3/lb. for 4'X20" sheets in various th. from Alaskan Cu. here in Seattle, I know some builders get it for around $2.75/lb. |
| I checked here, it's around 30NOK/kg, almost 4Euro/kg or 5USD/kg or 2.5USD/lbs. That is ex VAT. Prices change (rise) every day.... 1Euro=8NOK, 1USD=6 to 6.5NOK. http://www.norskstaal.no/varekatalog..._aluminium.pdf Example: Aluminium skipsplater, EN AW 5052/5754-H24/H34 (733-1) - NOK/KG Varenr Dimensjon Kg/plate <199KG >200KG >1000KG 733008 4,00 X 2000 X 5000 MM 112.00 49.80 43.57 33.62 As you see, the price is 33.62NOK/kg for 1000kg while it's 50NOK/kg for small quantities. |
| Fuel Prices Hurting Yet? | tom kane | Open Discussion: All Things Boats & Boating | 19 | 09-09-2005 11:56 PM |
| Prices of used boats, US vs UK... | Aquatek | Open Discussion: All Things Boats & Boating | 3 | 09-05-2005 06:57 PM |
| SplineWeights.com lowers prices | SplineWeights | Marketplace | 0 | 05-04-2005 09:54 AM |
| NZ (other) prices for Waterjets | Danielsan | Marketplace | 1 | 03-18-2005 08:13 PM |
| OEM Prices | Danielsan | Open Discussion: All Things Boats & Boating | 2 | 02-12-2005 09:18 AM |
