| Aluminium Boat Construction I have a question for all the boatbuilders out there. If I am building a small aluminium boat what type of aluminium should I use? The boat is 32 ft long and will be used in salt and fresh water. I have heard that any alloy in the 5000 or 6000 range is good but I am looking for something a little more specific. This is my first alloy boat and I have only limit knowledge about it. Any info or advice would be greatly appreciated. Thanks, |
| www.metalboatsociety.com Have quarterly mags and a discussion site - you need to log-on to get a password. great site. |
| Short answer: Get Dave Gerr's "The Elements of Boat Strength" |
| Typically, plating is usually 5083-H111 or H32 or 5086-H-111, H116, or H32. Structural members can be the same alloy, but extrusions are hard to find, therefore, a lot of people use 6061-T6 for the frames and stiffeners. The navy uses a lot of 5456-H111, but this is more expensive. A new alloy is out now called 5383-H116. It is higher strenth than the others, about 30% stronger on ultimate strength, and 58% stronger on yield strength, than 5083-H116, but it is also more expensive. Hope that helps. Eric
| How about boat design definitions | JonathanCole | Boat Design | 55 | 01-24-2010 05:48 PM |
| TP52s | mighetto | Sailboats | 2052 | 09-06-2007 11:46 AM |
| Has anyone here started a boat building business from scratch? | aqualoco | Fiberglass and Composite Boat Building | 61 | 09-27-2005 01:18 PM |
| Naval Architect Book? | Bill_Smith | Boat Design | 16 | 11-17-2004 11:08 AM |
| Boat Construction | Galib | Fiberglass and Composite Boat Building | 3 | 08-23-2004 07:01 PM |
