| AL600 Balsa - What are Pros and Cons? Using AL600 Balsa, it's my understanding that this core material saves on epoxy because it's already pre-coated. What advantages does this material have over open end grain balsa? What are the disadvantages? I am picturing the bond between the resin I apply and the balsa. If the balsa already has a layer or resin on it, aren't I just getting myself a mechanical bond to whatever coatings the company that makes AL600 used? If I penetrate the balsa with resin myself, would I get a better bond by brining my resin straight into the balsa itself? Am I over thinking this? |
| I don't think that you are overthinking this. I have wondered about this myself and will appreciate when you or someone else does a destructive test of like panels with AL600 and regular. Good luck and thanks for bringing it up! |
| Pros and Cons of jackshaft power. | Capt Sport | Metal Boat Building | 65 | 05-03-2007 08:11 AM |
| Jackshaft pros and cons | Capt Sport | Boat Design | 2 | 03-31-2007 04:40 AM |
| Stepped hulls pros and cons | AdrianRO | Powerboats | 8 | 11-24-2006 06:43 AM |
| Pros and Cons of an I/O system | shadowrack | Powerboats | 5 | 02-17-2006 08:11 PM |
| Inflatables, pros & cons? | Splint | Open Discussion: All Things Boats & Boating | 20 | 05-16-2005 01:54 PM |
