| Al - Cement While goggling for ferro-cement info I saw that expanded aluminum had been used as a lath in cement laminates for house construction. For boats, I suspect the aluminum core will eventually get exposed and corrode in salt water, but was wondering if there were real world attempts. Anyone know of Al lath being used in boats? Know of any surface treatments for the Al to enhance adhesion to the cement? I speculate that a CaO wash of the aluminum would produce a Al2O3 surface which would enhance the cement bond. An anodized phosphate wash might be interesting to try also. |
| Aluminum reacts heavily with cement creating gas bubbles within during the cure cycle. I wouldn't recommend using aluminum in ferro for that reason. I suppose you could coat it first as I do with any galvanized lath. Galvanized lath react with cement as well but to a lesser degree. |
What do you coat your galvanized materials with? |
| I use acrylic based concrete adhesive over anything with zinc in it but aluminum I use a polyacrylic clear coat to be sure I isolate it 100%. |
| Thanks for that info DrCraze. |
| Don't The temperature expansion ratios are completely incompatible too (between the cement/concrete and the mesh) |
| ferro-cement | tdw | Boat Design | 80 | 03-25-2011 05:58 PM |
| Proa-Cement | DrCraze | Boat Design | 28 | 10-24-2010 03:21 AM |
| without the cement | MikeJohns | Open Discussion: All Things Boats & Boating | 4 | 06-28-2005 12:31 PM |
| ferro cement | dwdwdw | Services & Employment | 1 | 04-05-2005 02:24 PM |
| ferro cement | dwdwdw | Materials | 3 | 02-12-2002 04:39 AM |
