| airstream for a cabin, weight of conventional aluminum cabin i have an airstream train 27 foot and have always wanted a houseboat. im wondering if the airstream could be a good readymade cabin for the hull. what is the approximate weight of a conventional bay/river style houseboat and what are they usual made of. i believe the airstream weights about 4500 lbs and of course a bit less without the trailer frame. |
| Without the frame you probably wouldn't have a trailer. Maybe you can utilize the trailer frame as a main part of the hull. |
| I would actually be inclined to remove the frame and save it for later use *as* the trailer. Weigh the thing without the heavy steel chassis, then figure out how much bouyancy you need to float it. If you have the bullocks to go "full-Hillbilly", your options are cheap and endless. ![]() |
| Put it on a ramped barge and you've got some real flexibility. The next question would be, power the barge or tow it...? -Tom |
| "Full-hillbilly" love it. You'll have to post some pictures : ) |
| Height of cabin | scanner | Stability | 14 | 10-27-2008 07:37 PM |
| panelling of cabin | chimay75 | Wooden Boat Building and Restoration | 0 | 04-02-2008 11:29 AM |
| Cabin Ventilation | darrenyorston | Wooden Boat Building and Restoration | 3 | 09-25-2006 09:00 PM |
| detachable cabin | djwkd | Boat Design | 3 | 08-12-2006 04:36 AM |
| 18-24' Cabin / Half cabin moulds | Louis | Boat Molds | 0 | 07-27-2005 03:48 AM |
