Old 08-29-2006, 08:59 PM
BobDoe BobDoe is offline
Rep: 10 Posts: 5
Airex foam core needed urgent
Hello All,
New poster here, I am desperate to obtain Airex foam core composite material for shipment to Bermuda. I require at least 10 full size sheets of 1/4" or 3/8" thickness. I have tried all the suggested dealers on the east coast without success, can ANYBODY help?? Canada, US , UK??
Current project is an 18' traditional design Bermuda dinghy, past projects have been 57' 3 mast schooner and various sizes of dinghys. All help gratefully recieved.
Old 08-30-2006, 10:30 AM
BT Composites BT Composites is offline
Rep: 10 Posts: 2
Do you need AIREX C70 ?.
Please specify weight kg/m^3
Please find enclosed Material Data Sheet AIREX C70
[URL="http://www.advancedcomposites.eu"]www.advancedcomposites.eu[/URL]
Old 08-30-2006, 12:23 PM
Rep: 10 Posts: 5
airex C70 full size sheets required
Greetings,
and thanks for reply,
Airex C70 FULL size sheets three eights inches thick.
How many sheets in a case,...prices?
Awaiting your kind reply,
Robert (Bob) Doe
Cedarberry Yachts.
Old 08-30-2006, 02:27 PM
Rep: 10 Posts: 2
Ariex HEREX C70 Specify weight variable from 40kg/m^3 up to 130kg/m^3 olso full sheet sizes are variable depend on specify weight...for example:
AIREX HEREX C70.55 10mm thick Specify weight 60kg/m^3 sheet size: 1450x1150mm
AIREX HEREX C70.75 10mm thick Specify weight 80kg/m^3 sheet size: 1500x1080mm
Olso you can buy Herex C 70.55/squares+grid30x30 mm. tl. 10 mm thick, weight 60kg/m^3 The sheet is one-side coated with a thin glass fibre scrim and is cut in squares of 30x30mm for working in 3D shapes.
I need all details then I'll be able to calculate Freight by Air Cargo PL Europe -> Bermuda. Air Cargo Freight price at this case will strogly depend on volume not by Gross Weight. Air Cargo offer payable weight and they use conversion rate: 1m3 = 167kg (1cu'ft = 4.729kg)
More details, please contact me by e-mail:
This is not Matketplace sorry for OT
Old 08-31-2006, 04:31 PM
Buckle's Avatar
Buckle Buckle is offline
Composite Engineer
Rep: 10 Posts: 83
cristex uk limited has recently aquired large quanitities of airex pvc core in a range of different densities and formats. Look them up on the web.
Lead time, two weeks which you will aggree is signicantly shortlier than 12+ weeks like the sole suppliers.
hope this helps
Buckle
(Composite Engineer)
Old 08-31-2006, 04:56 PM
Rep: 10 Posts: 5
Thanks Buckle,
will try that avenue,
all the best,
Robert,
Cedarberry Yachts,
Airex and any foam based hull materials tdamico Boat Design 21 03-04-2009 08:26 PM
Airex PVC core foam using ? signum Fiberglass and Composite Boat Building 10 02-01-2009 04:26 PM
AIREX Foam core Brad Seger Materials 3 07-28-2004 01:36 PM
Help Needed Urgent!!!!!!!!!!!!!! ashok3sep Software 0 06-16-2004 09:09 AM
Baltek - AIREX R63 Foam Guest Materials 1 07-25-2003 10:14 AM
