Old 07-24-2004, 06:21 PM
Brad Seger Brad Seger is offline
AIREX Foam core
I have a specification that calls for a 5 lb AIREX core that is 3.25" thick. How do I join sheets of AIREX together to get the thickness? I've only been able to find sheets that are less than an inch thick. They will be covered with fiberglass and used as engine stringers.
Thanks
Old 07-24-2004, 10:36 PM
tonyw tonyw is offline
Thanks
I have laminated sheets of Dininycell together when building Tornado catamaran hulls. Basically you can stick them together with resin, I use Vinylester for virtually everything else but I use unwaxed iso for laminating core. It is advantageous if you add a mix of Q-cell to the resin & make it pasty (this helps to fill the core & keeps weight down, although for stringers in a boat weight wouldn't be an issue). You have to perforate the core at regular intervals to allow the resin to spread & prevent air entrapment. This may also not be an issue for your application. You have to apply plenty of weight to the sheets (I use a vaccuum pump), but for what you are doing you can probably get away with Besa blocks or similar. The main thing is to get the pressure as constant as possible. Remember, you're not looking for super strength here, you just need to make the shape, & the laminate around the outside gives you your strength.
Old 07-28-2004, 12:54 AM
War Whoop War Whoop is offline
Rep: 23 Posts: 204
You can use B-70 Core Bond from ATC Chemical But if you like Epoxy then Spa Bond 740 From SP Systems.
Slippery when wet.
www.cheetahcat.com
Old 07-28-2004, 01:36 PM
brian eiland's Avatar
Rep: 728 Posts: 1,859
Multiple Core Layers
Just make sure you are not bonding the sheets of core material together in such a manner that they will experience large shear forces in line with these bond lines. You want the forces to be perpendicular to these bond lines....and preferrable this bond line to exist on the neutral axis of the 'beam'. Even then, multiple layers of core material is not such a great idea.
And don't use poylester resin...the only thing it really likes to stick to is your shoes and your skin...it doesn't even like to stick to itself!
RunningTideYachts.com
Distinctive Expedition Yachts
Airex and any foam based hull materials tdamico Boat Design 21 03-04-2009 08:26 PM
Airex PVC core foam using ? signum Fiberglass and Composite Boat Building 10 02-01-2009 04:26 PM
fiberglass over molded foam core delphidiemaker Sailboats 1 10-01-2005 06:58 PM
PVC Foam or Polypropelene Honeycomb sandwich core plimsoll_line Materials 7 03-20-2005 07:00 PM
Baltek - AIREX R63 Foam Guest Materials 1 07-25-2003 10:14 AM
