| Advice/expirtise needed: Hello, I am a MBA student at Southern Methodist University - Cox School of Business. I am working on a five-year business plan project for a start-up boat manufacturing company. Not only is this a required project, but also I would like to see if this is a feasible project to actually pursue. My question is how many layers and of what kind (mat, weave, weight?) of Fiberglass media would you recommend for a 14.5' planeing, air-entrapment hull, given your experience? This is only for forecast financials. I have sourced all my materials based on estimates based on scraps of info gleaned here and there, but I am unsure if my estimations are accurate. Inaccuracies in materials requirements can have a significant impact in my financial projections. The boat will be a 14.5’ planeing catamaran powerboat, with a stepped hull and center pod. I expect the boat to utilize a 50 hp motor. The primary intended use is flats fishing in protected waterways. The target weight is 700-800 lbs. There will be two models: 1) Fiberglass vacuum resin infused 2) Kevlar/Graphite weave resin infused I have no idea of material weight to use, type of media (mat, weave, etc) The measurements are: 14.5’ long 7’ wide 3’ gunwales I do not have any cad drawings, as the time frame is very tight on this project. If the numbers workout, I will continue to pursue this project further. Let me know if there are any other details that need further clarification. Thank you once again. Dave |
| Check out Aksano Catamarans, they make almost exactly the boat you described. |
| Thank you, I have, but maybe they can help me with my project. Thank you for the suggestion. |
| SC advice needed | workboat | Software | 4 | 07-31-2007 06:08 PM |
| Advice needed for foam job | Frosty | Fiberglass and Composite Boat Building | 12 | 08-19-2006 02:27 AM |
| Hi everyone.. Advice Needed | LoneRider | Open Discussion: All Things Boats & Boating | 10 | 06-23-2006 12:55 AM |
| Advice Needed | KSC | Boat Design | 1 | 02-20-2005 10:44 PM |
| Advice needed! | biggathanjesus | Materials | 6 | 05-28-2004 11:44 AM |
