Old 01-29-2005, 01:36 PM
lprimina lprimina is offline
Rep: 35 Posts: 103
5 ply luan
Is the 5 ply luan with exterior glue worth a crap for building boats for sell. I have a chance to buy 150 sheets at around $8.00/sheet.
Thanks for the answers
Ben
Old 01-29-2005, 02:07 PM
D'ARTOIS D'ARTOIS is offline
Rep: 311 Posts: 1,069
For what would you like to use it? In any case at 8 $ per sheet it is definately not meant to be a rip off. Is it WBP quality? Earlier in this forum I have replied with a small test: take a piece and put it for a certain period, 5-8 hrs, in boiling water. Does it delaminate within the 4 hours - the material is just "lumberyard"
quality, but even at hat price/quality not expensive. If you want to buy the lot, look for gaps in the laminate. To test that, cutt a few pieces off and look for interlaminar gaps. If there are, you deal with 2nd choice - still at 8 $ a sheet not expensive. It could than used in housing projects and resold with a profit.
Old 01-29-2005, 05:33 PM
Rep: 2891 Posts: 8,795
What is the thickness, 5 ply 1/4" stock may be a good deal, but 5 ply 3/4" stock would likely be junk. Any time you buy 150 sheets of plywood you'll get a price break. If this is considerably lower then the current retail, then buy it and resell it. Use the profits to buy some real marine grade stock. My understanding of ply construction is the glue used for exterior is the same as marine, but the interior lumbers used in the sheet may be quite prone to rot, void size and count is unacceptable in exterior grades where this is not the case with marine grades.
Old 01-31-2005, 01:36 PM
JR-Shine JR-Shine is offline
SHINE
Rep: 50 Posts: 282
Find out if the intereior plys are made of the same wood as the exterior plys, check for any interior voids.
If its made of the same wood throughout, have little to no voids, water proof glue, I would say your getting a deal.
Old 01-31-2005, 03:33 PM
Merbau
Additional info: in Holland it is mainly used as wood for door- and windowframes;
it is not available in sheets - nowhere in Holland - only Meranti (lower quality)
costs: Euro 1700,= per CU meter ( 1.00 Euro = 1.30 US$)
Old 02-02-2005, 05:01 PM
Rep: 35 Posts: 103
It is 5.22mm and the inner layers are not the same.
I will stick with akume at least it has the loyeds of london stamp on it.
Thanks for the info
Ben
Using double layers of marine ply cat28 Materials 5 07-05-2005 01:26 PM
Luan (philiipine mahog0 vs poplar bjl_sailor Wooden Boat Building and Restoration 9 02-12-2005 12:21 PM
Go with the Luan or is there a better alternative? darr Wooden Boat Building and Restoration 4 01-05-2005 03:50 PM
Australian source for teak & holly ply Willallison Materials 0 10-23-2004 06:29 PM
New to the game. Aluminium or marine ply? mannjo Boatbuilding 6 01-04-2003 01:00 PM
