Old 11-23-2009, 08:14 PM
rallyview rallyview is offline
Rep: 10 Posts: 2
4'x20' pvc sheets for boat building
I'm working at a lumberyard and we've started getting in these 4'x20' sheets of pvc. They come in 3/8, 1/2, 3/4, and 1". They have the same density/ weight as yellow pine plywood.
My questions on the sheets are:
1 will they deform and creep overtime due to the sun. how would you frame to minimize this? The panels i've seen are supposedly stable to 158 degrees F
2 Would a pvc solvent glue like used in plumbing work give a flexible enough bond for boat construction. Would i be better off using a high temp plastic welder? Polyurethane, polyester resin? G-flex?
3 I envision using these panels for stitch and glue designs. Will the large movement of these panels over the course of a heat cycle be a problem? Since the whole hull will be built of the same material i think material movement will not be a problem but maybe i'm overlooking something.
any thoughts?
Old 11-23-2009, 09:35 PM
PAR PAR is online now
Rep: 3125 Posts: 9,401
Take one of these PVC sheets and make structural comparisons to the same thickness plywood. What you'll find is it's not as stiff and several other physical short comings. Couple this with PVC's difficulty in UV break down, ability for paint to stick to it and adhesive issues, makes it a poor material for planking as you suggest.
One of the biggest elements of stitch and glue construction are the seam reinforcements, replacing traditional longitudinal structural elements. This is done with fillets and fabrics set in epoxy. PVC cement can't do this. You could heat weld to a frame, but you'll lose the weight savings advantage of stitch and glue, coupled with the other stuff, making you wonder, why bother.
Give it a try, but you'll find that very little sticks to it well, it's not self supporting for it's weight, is heat sensitive (lots of movement), etc., etc., etc.
Old 11-23-2009, 09:42 PM
JRL JRL is offline
Im with stupid
Rep: 25 Posts: 83
This article was helpful to me when deciding to use PVC. Im only making a casting deck with it on a very small canoe. Poly supposedly sticks to it (am testing that at the moment: 45 grit sanded surface, CSM, Poly layup). If all else fails Ill use it in the same manor as Bertram (i.e. nothing to structural).
http://www.bertram31.com/proj/tips/pvc.htm
Building a raft w/ pvc pipe? Aberamonli Boatbuilding 31 01-08-2012 10:23 AM
Looking for ideas on building a PVC river raft The Guy Boat Design 2 06-28-2007 11:08 AM
Where to get polyethylene, PVC, or Hypalon sheets? SWG Materials 1 01-06-2007 07:44 PM
3/4" sheets 4lb-6lb White PU or PVC Foam pelagiko Boat Design 1 07-24-2006 09:27 PM
building with PVC core foam signum Fiberglass and Composite Boat Building 3 11-26-2005 07:02 PM
