Old 05-03-2008, 09:00 PM
wet-foot wet-foot is offline
Rep: 10 Posts: 175
2 part poly paint - is it safe to breathe the fumes
I want to paint ( roll and tip out ) a small boat with a good 2 part polyurethane, are the fumes dangerous? This will be done in an attached garage.
Old 05-03-2008, 09:27 PM
bxbbuddy bxbbuddy is offline
Rep: 10 Posts: 3
Yes. Air supply is needed.
Old 05-03-2008, 09:46 PM
Previous Member
Rep: 0 Posts: 0
most contain isocyonates, they will damage your lungs forever, any mask cant filter out isocyonates, including carbon filters
Old 05-03-2008, 10:05 PM
the1much's Avatar
the1much the1much is offline
huh? hehe ;)
Rep: 547 Posts: 3,949
YES the fumes are as dangerous as having an open 5 gallon gas can in every room,,,and NO im not exaggerating,,,does anyone you care about come in ya house?,,are you 100% sure you or 1 of those people coming in (even months after) wont have a BAD reaction to the 100and so BAD chemical fumes given off? ,,does anyone coming over have respiratory problems?,,,would ya like going to bed to the smell of the paint for a while?(,,hehe,,i would ) ,,,and ive messed with paints for years,,,and dont follow safety procedures,,*cough*,,but,,if *arrrrrrrrrrrrrrggggfff* I could get,*hhhhhhhhhaaackkk* a breathe,,*cough**hack**spit***drool**,, i'd tell ya ,,,,ccccccceaaaaaaaaaaaaargggggggggrrrrrrrrrffffffff* ,,not ta worry
hehe
hehe ,,,,,Jim------>
Old 05-04-2008, 04:18 AM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
Yes, Very.
Old 05-04-2008, 11:02 AM
grady's Avatar
grady grady is offline
Novice
Rep: 70 Posts: 459
Some Info
Here's some info gained by exhausting research. Have osha doc's etc to back up conclusions will post links upon request.Breath of fresh air!!!!!
Fair winds & calm seas
Old 05-04-2008, 05:42 PM
missinginaction missinginaction is offline
Rep: 361 Posts: 297
I'm likely to gat hammered for this, but I've rolled out two part polyurethane paints (Interlux Perfection) on a number of occasions and have had no issues with toxicity.
My understanding is that the isocyanates in the system do not become airborne unless one is spraying the paint. You definately don't want to spray these two-part paints unless you have an outside air source and an airtight suit.
My experience is that the thinners that you must use with these paints are very potent. I wear a tyvek suit, gloves and an OSHA approved mask with proper canisters for organic solvents. I shave before I paint so that I get a good seal between my face and the respirator. The cansiters do a good job of filtering out the solvents as I cannot smell them while painting.
Good Luck,
MIA
Old 05-04-2008, 08:51 PM
Landlubber's Avatar
"I've rolled out two part polyurethane paints (Interlux Perfection) on a number of occasions and have had no issues with toxicity."
that were immediately noticable......did you have a blood test to back up this observation.....believe me any volatile solvent based paint is not good for your health. I too have used them for years, but expect to pay for it later (if not sooner). Be sensible and protect your lungs.
There are old pilots and bold pilots, but there are no old, bold pilots.
Old 05-05-2008, 06:14 PM
Rep: 10 Posts: 175
I Can Smell the Gloss
Interlux Perfection seems to be the DIY-er's choice for a brush on 2 part poly.
Surprisingly the manufacturer shows it being brushed on with no breathing protection at all! They do mention the dangers of spraying. Sanding seems to be a bigger concern? When tipping off the painter has his nose 2 inches from the wet surface ............. so I guess its safe to brush. here's one of a few videos applying Perfection on YouTube; Smell the Gloss of Perfection
Old 05-05-2008, 06:20 PM
Rep: 10 Posts: 175
In the video he's using one of those round head brushes ......... are they really better than a good regular style brush? thx
Old 05-06-2008, 06:20 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1059 Posts: 2,194
I like Brent Swains idea of running some clear polypipe from a simple home respirator to the outside of the shed.
Those complex filter systems get gummed up quickly when spraying, and cost a small fortune to replace.
Old 05-13-2008, 08:23 PM
Rep: 10 Posts: 175
Does anyone know if it really makes a difference to tip off with a real high quality brush? It seems to me the roller is responsible for laying down a nice even coat and the brush simply removes the stipple effect.
Old 05-13-2008, 09:05 PM
Landlubber's Avatar
Yes the type of roller cover is very important, but so it the quality of the tip off. If, for instance, you useda coarse pig bristle brush, it would rake the surface and leave indentations in the lovely even roller job, if the brush was a fine quaility, it will greatly reduce the amount of raking that the bristles leave. Also, an old brush is often better than a new one, because the hairs have been tapered through use, and abraded away to a finer tip.
Old 05-13-2008, 10:09 PM
the1much's Avatar
huh? hehe ;)
L.L. is absolutely right,,,,(even though i dont snail paint hehe) every GOOD snailer says the brush is just as important,,,in fact maybe more,,,your roller puts the paint on,,your brush gives you your "finish",,,,so i've heard,,hehe
Old 05-14-2008, 01:25 AM
Landlubber's Avatar
the1much,
Hey mate, try it sometime, it works!
Fumes from Epoxy Resin? MarkIFC Fiberglass and Composite Boat Building 37 01-03-2008 06:27 PM
Can I use this stuff for a two-part poly primer? mongo75 Fiberglass and Composite Boat Building 0 09-16-2007 10:53 PM
Fumes and Sparks Grebbo DIY Marinizing 52 08-01-2006 10:58 PM
Hazardous materials/fumes in small spaces rcgerard Fiberglass and Composite Boat Building 12 11-27-2005 04:16 PM
fumes accent33 Propulsion 18 05-26-2005 09:19 PM
