  #31
Old 09-08-2010, 04:51 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1874 Posts: 3,357
Originally Posted by missinginaction View Post
Here's another way to look at the epoxy/polyester issue. OK, bondo (you know, the body filler used on cars) is based on polyester. Over the years before I started playing around in boats I used it to touch up my cars. It NEVER held up for more than one winter. Now I use use boat building epoxy and fiberglass/fillers on the cars when I want to repair a rust spot. THESE repairs, done with epoxy, last.
So for the 10,001 time no polyester, no, no, no. Can't afford epoxy? Then get a second job and wait until you save enough to do the job right.
BTW, Troy, you need a new friend
MIA
He said"used to have...". May he rest in peace. You are right either way.
Hoyt
  #32
Old 09-08-2010, 05:30 PM
apex1
Originally Posted by SamSam View Post
then the thread is pretty much ended by post 7. .
Would say it ended here.
  #33
Old 09-16-2010, 07:44 AM
Steve W Steve W is offline
Rep: 360 Posts: 686
Ok,while obviously epoxy is the way to go,BUT,polyester does stick to plywood and is what was used for tabbing in bulkheads etc in tens, if not hundreds of thousands of the older stick built production glass boats throughout the world,in fact i have never in my 35yrs or so in the trade seen a factory built boat where they used epoxy to tab structure in and in most cases of faliure it can be attributed to poor maintainence,ie,the bottom of bulkheads never rot out unless some ***** owner allows water to lay there deep enough to be above the glass tabbing for extended periods of time. That said,epoxy is just so much better it makes no sense to use polyester for tabbing anything in, if cost is your reason to want to use polyester you dont need to use the big name brands,there are plenty of smaller names which work as well for less $$ such as Raka,progressive etc.
Steve.
Working Time, Pot Life, Open Time, Gel Time... Huh?! CatBuilder Materials 48 08-01-2010 02:38 PM
polyester over plywood: advise needed pescaloco Fiberglass and Composite Boat Building 29 06-14-2009 09:34 AM
Protecting Plywood with Polyester Resin asianbandit Materials 16 05-04-2009 02:50 PM
Polyester resin and plywood Whale1 Fiberglass and Composite Boat Building 4 01-22-2008 07:30 PM
Difference between infusion polyester and regular hand lay-up polyester? erikssonniklas Materials 2 01-14-2008 10:48 AM
