Old 09-02-2012, 10:20 AM
Suggly Suggly is offline
Rep: 10 Posts: 4
Weed Blocking Intake on Vicalen Jet
I have an old Vicalen Jet & use it in a lake with long ribbon grasses which seasonally float to the surface. This blocks the intake filter on the bottom of the hull forming a mat. Has anyone had this problem, if yes how did you solve it please??
Thanks All
Suggly
Old 11-08-2012, 04:53 AM
Rep: 10 Posts: 4
Weed Blocks Jet Intake!
How do you retrofit an intake RAKE to an older style Jet??
Old 11-08-2012, 06:03 AM
Frosty Frosty is offline
Previous Member
There is many types of propulsion all suitable or not suitable to various kinds 0f use.
A weeded lake would not be suitable for jets and would fall under the air boat catagory.
A rake type strainer would only eventually block the intake or at least restrict it rendering it unsusable.
Old 11-08-2012, 01:26 PM
Previous Member
I don't believe there is a solution you would consider reasonable.
You might want to sell the boat and buy one with a prop.
Old 11-09-2012, 12:03 AM
tunnels tunnels is offline
Previous Member
Thanks All
Suggly
BUY A HOVER CRAFT !!
Old 11-09-2012, 09:02 PM
tom kane's Avatar
tom kane tom kane is offline
Rep: 389 Posts: 1,751
Google CAM.A.PROPULSION, Pivotal Drive, an easy to build trimming propulsion drive that will go most anywhere safely and easy to free from weeds if it does catch some weeds and is safe from damage. Run it in Surface Propulsion or lowered down 20 degrees like a conventional prop drive.You can even fit a water jet that is trim able too. Try www.youtube.com/SuperHakane for an Air boat with horizontal fan for something really innovative.
tomkane
Old 11-20-2012, 04:43 AM
Rep: 10 Posts: 4
Suggly - Jet with weed blocking intake filter
Submarine Tom is probably close with 'sell it and buy a boat with a prop"; has anyone converted from jet to stern drive????? The engine is 150hp Hino diesel.
Suggly
vicalen jet whitepointer23 Jet Drives 3 01-22-2012
12:16 AM
jet ski motor water intake? racing fan Jet Drives 2 05-14-2011
07:47 PM
Jet Drive for 10m tour boat - weed and shallow water solution needed yodani Jet Drives 65 12-19-2010
07:49 AM
Blocking posts? alanrockwood Forum Questions and Suggestions 2 06-27-2010
01:40 AM
moving the jet pump and intake back rbtlen Jet Drives 2 10-25-2007
04:08 AM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
