Old 02-27-2011, 02:36 PM
milcio79 milcio79 is offline
Rep: 10 Posts: 2
WaterJet design??
Hi im making a design of a HSC an d I need 2 engines 320 each, with 2 waterjets, I selected the Ultradynamics UltraJet 305. Now, the question is that my boat has a 23° deadrise, so the waterjets has to be inclined this angle. żis there any problem by inclining them?
Old 02-27-2011, 04:16 PM
baeckmo baeckmo is online now
Hydrodynamics
Rep: 962 Posts: 631
No problem with the jets as such. Just be careful so that you get the shaft lines correct, i.e. the engines will not stand parallell to the keel when the jet intakes are installed in straight FW-Aft position.
Old 02-28-2011, 03:37 PM
Rep: 10 Posts: 2
Thanks man, very useful!!
Old 03-01-2011, 04:57 AM
anthony goodson anthony goodson is offline
Rep: 241 Posts: 391
milcio, just in case you become confused, bear in mind that a standard off the shelf 305 has a parallel shaft, this problem will only occur with the 5 degree shaft option, Ultrajet would be unlikely to spec this for your application with a 23 degree deadrise.
waterjet propulsion hawk Jet Drives 10 02-02-2011 03:06 PM
waterjet aryanboy Jet Drives 34 11-29-2010 04:51 PM
Tiny waterjet from Mokai in renewed tri-design ASM Boat Design 7 08-23-2010 12:38 PM
Waterjet design NavArch007 Jet Drives 1 06-23-2010 08:45 AM
waterjet underwater EStaggs Jet Drives 11 09-24-2007 01:07 AM
