Old 08-11-2006, 03:51 AM
COLD-EH''s Avatar
COLD-EH' COLD-EH' is offline
Rep: 10 Posts: 62
Water Skiing and Jets
I see the Bombardier jet boats and Sea Doos do some pretty incredable stuff pulling wake boarders and skiiers. I never thought a jet would be a good pull boat however I have never been behind or pulled anyone with one. Anyone have experience?
Old 08-12-2006, 05:19 AM
Frosty's Avatar
Frosty Frosty is online now
Rep: 1528 Posts: 5,518
Not great,-- but if your desperate it'll do. Not like a Mastercraft, when the rope pulls tight you shout go. Have you ever seen the cable ski tow. Like a small lake with a cable running around overhead-- now theres a pull you wont forget if you ever get your shoulders back in there sockets.
Old 08-12-2006, 11:05 AM
COLD-EH''s Avatar
Rep: 10 Posts: 62
I didn't think so! That's the goal, Matercraft style boat. Good to have goals!
Old 11-25-2006, 08:06 AM
TJP TJP is offline
Rep: 10 Posts: 2
I use a hamilton jet boat fitted with a two stage jet and 302 Ford for skiing. I weigh 110 kilos and it pulls me out on a single ski if I drop a foot. Wont deep water barefoot start me though. You need a longer rope to get away from the turbulent water. Makes a perfect wake for boarding. A three stage jet and a 351 would give better pull.
Old 11-25-2006, 09:40 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Big difference there, between a 302/Hamilton and a 900cc Rotax. TJP's setup would have more than enough holeshot and should be able to hold a stable speed; jetski's generally can't do that. I haven't skiied behind a jet-ski, nor do I want to. The wake is completely the wrong shape for skiing and just as wrong for wakeboarding. And the things hold a straight line about as well as a bouncing football does, when the skier's off to the side. Where they are good towboats, is apparently on a tricks course, where the rider's not relying on the wake so much as the ramps and rails to make his jumps. The bigger jetski-engined boats in the 18' range tow a fair bit better than the PWCs, but I don't know of anyone who prefers one to a real towboat like a Tige or Malibu.
Old 12-07-2006, 11:20 PM
enzo24 enzo24 is offline
Rep: 10 Posts: 8
i agree with marshmat. jet boats don't put out the right wake for wakeboarding. if you are looking for a towboat you have to go with the big tow boat manufacures like Malibu Centurion or Tige.
Old 12-11-2006, 09:59 PM
Willallison's Avatar
Willallison Willallison is online now
Rep: 2283 Posts: 3,468
Jets don't really stack up for any sort of waterskiing. As suggested the wake is generally poor - incidentally shape is just as important for trick skiing as it is for wakeboarding. They are worst for slalom as they don't have any real 'grip' in the same way as a conventional prop does. They also add nothing in terms of lateral plane - like a skeg does - to help prvent the boat from being pulled sideways.
Will
Imaginocean Yacht Design
www.imaginocean.net
Jets Drives RDB Jet Drives 5 05-30-2007 04:42 AM
Mercury Sport Jets, 4-Stroke? speedboats Jet Drives 0 08-01-2006 10:18 PM
Brackish water corkhopper Wooden Boat Building and Restoration 2 10-07-2005 08:27 PM
No water in oil pan, But water in oil filter? midtower Gas Engines 14 03-19-2005 06:43 PM
Fuel, water, black water tank construction kudu Boat Design 12 07-25-2003 07:54 PM
