| rubber coupling angle I am replacing the engine in my Dateline,presently the rubber coupling between engine and jet drive is running at an angle of just under 5.5 degrees. Do I need to straighten this connection up or is that perfectly acceptable for this type of coupling? |
| Straighter the better. |
| yes look only cv types like running out so do you know how to set up using a clock dial? if not then straight edge and feeler gauges there are two types of alignment Parrellel and angular if you have a messenger like msn or yahoo I can talk you thru this |
| Thanks,have sent an email |
| Dateline bikini shaft coupling | bullet | Jet Drives | 23 | 10-27-2009 12:37 PM |
| How to fix a new gun-whale rubber strip. | tropicrows | Boatbuilding | 1 | 10-23-2006 08:42 AM |
| identifying rubber on inflatable | w_water | Materials | 6 | 07-16-2006 11:29 PM |
| Relationship between angle of attack of keel and heel angle | stelios | Sailboats | 9 | 05-29-2006 02:14 PM |
| polyurethane rubber | Materials | 1 | 06-29-2002 09:20 PM | |
