  #31
Old 01-14-2011, 10:41 AM
anthony goodson anthony goodson is offline
Rep: 241 Posts: 391
Having given this more thought on my walk ,I do remember removing a device from a Hamilton 212 I think it was. some years ago This was not linked to the throttle just the bucket ,and it would lock it in any position .regardless of throttle position ,I was asked to remove it because the owner said it often jammed and he was worried it would cause an accident. I have never seen another one.
  #32
Old 01-14-2011, 10:46 AM
Rep: 1493 Posts: 7,447
I think that's the one.
  #33
Old 01-14-2011, 11:19 AM
ericrunner ericrunner is offline
Rep: -24 Posts: 35
i still think a gear box would be a lot better but i will do with what i have for now ! If someone comes across a part number for a gear box let me no thanks
  #34
Old 01-14-2011, 11:47 AM
Rep: 241 Posts: 391
With a gearbox ,if your motor takes it's cooling water from the jet ,you may have to consider mounting and driving a separate raw water pump ,good luck with your project.
  #35
Old 01-14-2011, 12:30 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
You could drop the buckets on this boat at speed and bury the bow anchor which was something for 62 feet (20m) and 60 tons. You'd be stopped in about two boat lengths.
I think I get it now: 360's while docking is like a dog that turns around a few times before laying down.
-Tom
  #36
Old 01-14-2011, 02:25 PM
speedboats's Avatar
speedboats speedboats is offline
Rep: 124 Posts: 117
It's called a de-tent. You can adjust how much tension it applies but it was designed more so that the thrust from the nozzle doesn't kick the bucket back into the 'up' position. It is very hard to pull the bucket into the jetstream at full throttle anyway, you do need to back off a ways while the bucket is applied then mash it again.
the de-tent is the box looking thing on a shaft. American Turbine also utilise a similar system for their HTRII reverse system
reverse jet drive-dsc03343.jpg  reverse jet drive-dsc03415.jpg  reverse jet drive-dsc03556.jpg
  #37
Old 01-14-2011, 08:14 PM
RivrLivn RivrLivn is offline
Rep: 10 Posts: 25
With 360 turning I was referring to the amazing slow speed maneuverability I get from my Hamilton hj212. I can get up in a narrow channel and do quick 180 by manipulating the reverse bucket and throttle. Also coming into the river dock, even in heavy current, can “walk” the boat sideways. Now I do enjoy the high speed spins and bow diving stops too.
  #38
Old 01-16-2011, 02:11 PM
jbmboats jbmboats is offline
Rep: 10 Posts: 19
bucket
here is the pic of the rev bucket you will need for your yamaha jet pumps
  #39
Old 01-16-2011, 10:40 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
I seem to remember that when reversing a jet you would turn the steering wheel the opposite direction to what you would normally.
  #40
Old 01-16-2011, 11:29 PM
speedboats's Avatar
Rep: 124 Posts: 117
You may wish to custom adapt a different type of bucket that doesn't pivot as part of the nozzle. While this will work for an 'adequite' reverse, it won't enable the type of manouvers described prior.
  #41
Old 01-17-2011, 03:57 AM
Rep: 241 Posts: 391
Good morning Frosty ,see my post No 13 ,ericrunner also concur weth speedboats ,this type of bucket will be more complicated to mount, and will only work if you attach it to the nozzle. The more common bucket will work mounted on the jet bodies or the transoms.As for manouvres, they will be very restricted with your setup anyway. But if you do manage anything spectacular make sure you video it !!
  #42
Old 01-17-2011, 11:46 AM
Mariner
Correct there old timer. It's a very hard habit to break when you make your "flare" on final to the dock NOT to spin the wheel to opposite lock and go to reverse. Instead, you simply leave the wheel right where it is, hit reverse and it's a thing of beauty.
Of course, any landing you can walk away from is a good landing!
-Tom
  #43
Old 01-17-2011, 10:42 PM
speedboats's Avatar
Rep: 124 Posts: 117
just think in the mode of; "which side of the boat do I need my thrust?" and all will be fine, or if that's difficult then the bow will always go in the direction you turn the wheel...
Jet, Jet Pump, Waterjet, Jet Drive vs Prop brian eiland Jet Drives 45 08-27-2010 08:04 PM
Transmission-free surface drive? (jet pump reverse bucket) srimes Surface Drives 19 01-15-2010 06:04 PM
older v-drive has no reverse tentantoes Inboards 2 07-06-2008 08:34 PM
mercruiser out drive reverse problem badbowtie Powerboats 1 05-29-2007 02:43 PM
reverse flow on jet drive LEASEGUY Jet Drives 2 08-06-2006 08:19 PM
