Old 02-12-2010, 12:49 PM
autobahnbuyer autobahnbuyer is offline
Rep: 10 Posts: 4
retrofit jet drive
A few years ago I ran across a company that was building a "retrofit" jet drive.
I believe it used a standard Berkley type pump and drive. It was sold with either V8 or V6 power. The motor was mounted above the pump and was built into its own Positive boyancey housing. This housing would be attached to the back of the transon and replaced the drive unit where a standard inboard outboard was located. Does anyone know who this manufacturer is. I believe they were located in Florida. Thanks for your Help!
Old 02-12-2010, 01:18 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Heya,
You're probably thinking of the JetPac, built by Sword Marine. It was a conventional inboard diesel or gas engine, mounted above a jet pump in a self-contained housing that would be bolted to the transom like an outboard. It's been mentioned in a few old threads around here. There was some kind of factory shutdown recently and rumour had it that they would be back in production a few months ago. I haven't heard much about it since early last year.
Old 02-12-2010, 01:54 PM
Rep: 10 Posts: 4
Jetpac
Thanks for your help! That the unit I am thinking of.
Old 03-08-2010, 11:11 PM
quikfix51 quikfix51 is offline
Rep: 10 Posts: 2
jet pac
i have one of these without the motor....what are they worth? The jet drive turns freely and looks new...neel517@hotmail
Jet, Jet Pump, Waterjet, Jet Drive vs Prop brian eiland Jet Drives 45 08-27-2010 08:04 PM
Jet drive ted655 Outboards 6 05-16-2008 07:07 AM
Converting from Jet drive to Stern drive gearhead496 Boat Design 9 03-22-2008 11:23 AM
jet drive? or stern drive? Toby100000 Jet Drives 2 08-04-2007 03:32 AM
Retrofit turbine engine to powerboat. Verytricky Propulsion 21 02-24-2006 01:54 PM
