Old 03-27-2008, 11:04 PM
ejkob ejkob is offline
Rep: 10 Posts: 4
Rebuilding a 350 small block with Berkely jet
I have a 72 Glastron 18.5ft fiberglass classic with a small block 350 and a JCB Berkeley jet drive. I have been in the process of restoring the boat and this year I want to rebuild the motor. I plan on replacing the old Rochester qudrajet carb with a new Holley. Last year at the upper end of the throttle, the motor acted like it was missing or starving for fuel. For now, I am looking at a 600 CFM but I am being told that the Holley replacement for a Qjet is 650 to 750CFM. Can someone quide me as to the correct carb to get and as I rebuild the motor, what CAM should I consider to power the jet. After all the work is complete, should I change back to the stock A impeller?
Thanks
Old 03-28-2008, 12:27 AM
jim lee's Avatar
jim lee jim lee is offline
Rep: 217 Posts: 338
A 650 spread bore would work great. I've heard the center hung float bowls are the ticket 'cause they take the rough ride better.
A impeller B, C or D it all depends on the power band of your engine. Building a jetboat engine is NOT like building a car engine. Choose an RPM that you feel comfortable with. Dump ALL the HP at that RPM. (Like a 2 stroke, very peaky) Ignore those that talk about torque. Once you choose your Max HP RPM, build the engine. Once the engine is built and running, start with the A impeller and have it trimmed 'till you hit your target max HP RPM. Done!
Here's THE MAN for jetboat questions : http://home.pacbell.net/jmcclure/
And here's a video all about Jack (Owner or MPD) : http://www.youtube.com/watch?v=_ugp8xfglNw
Good luck!
-jim lee
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
Rebuilding a 350 small block with Berkeley jet ejkob Gas Engines 1 04-16-2008 08:25 AM
Big block or Small block? Verytricky Inboards 15 10-10-2007 01:04 PM
Small block camshaft tuantom Sterndrives 3 05-11-2007 02:28 AM
chevy small block (305) rebuild ericklee DIY Marinizing 20 11-29-2006 05:16 PM
what is the normal operating temp for 305 small block mercruiser chevy? mattcat79 Gas Engines 2 08-22-2006 11:12 PM
