Old 03-19-2010, 10:10 PM
gibtron02 gibtron02 is offline
Rep: 10 Posts: 3
RC boat - What is the best Propulsion system?
Hello, I am working on a custom RC boat (battery powered). It is a catamaran style (2 hulls) and it is being built to carry a maximum load of 60lbs at 7mph. Based on the hull design it has been determined that the total drag force to overcome is 8.50 lbs (per hull). So I know I need a propulsion system that can give me greater than that. This is where I'm having a very difficult time determining what the best means of propulsion for my boat should be!!
I've looked into using propellors in a channel, jet drives using both a centrifugel pump and axial impeller style pump. I have no experience with this sort of thing and could use some serious advise!! Thanks in advance!!
Old 03-19-2010, 11:10 PM
Boston's Avatar
Boston Boston is online now
Rep: 1457 Posts: 3,355
if you google propcalc you should find an application that will determine the HP needed and the prop for a given hull form
I am skeptical of the deniers diatribe
Propulsion system selection amamini Propulsion 9 08-01-2009 02:04 PM
Propulsion system Anilkumar Boat Design 0 01-27-2009 05:47 AM
New propulsion system for my boat multibeamer Surface Drives 3 07-18-2008 09:18 AM
New propulsion System tom kane Open Discussion: All Things Boats & Boating 35 06-09-2005 12:06 AM
Another new propulsion system DEDave Boatbuilding 12 09-09-2004 10:25 PM
