| PWC normal pump rpm Greetings , Does anyone know what the normal rpm range is on a PWC with direct drive ? When I say "normal" I'm speaking of the range of best performance. I also guess that "most" modern PWC's are infact direct drive ? Thanks! |
| Depends on the PWC, and yes, they do tend to be direct drive. A PWC's engine will often run 5000-6000 rpm, if not more. Manufacturers will thus tune the pump to be at its best performance at the engine's best-power RPM (usually near its top end on these high-strung motors), and will set the impeller to absorb the engine output power at that speed without cavitating. So you end up with a very small impeller turning very fast. Check the max RPM and power rating on the engine a jet-ski pump was designed for, and that's probably the pump's optimal input.
| Thanks marshmat. So then its possable to have a pump tuned to be more low end torque than speed . Thats kinda what I'm looking for . Who does this sort of tuning? Solas ? |
| Power absorbed by a water jet is very predictable. It works on a cube function. Basically, If you half the rpm's, horsepower absorption is reduced to 1/8th. I.E. a pump that absorbs(turns to thrust)100 hp@6000 will absorb 12.5 hp @ 3000 rpm's. That is why the 14' river jon boat I am building is using a large high pitch Yamaha pump only using 25HP@3600 rpm. I am hoping the pump won't mind a little sand and gravel so much at the lower rpm's. This site has good basic design information.: http://www.ultradynamics.com/section...nal/design.asp See: Waterjet Impeller Nomenclature (Impellers Demystified) Have fun, Gary C. |
| pump vibration at higher rpm | hands87 | Jet Drives | 3 | 07-27-2007 08:33 AM |
| Risers hot on one side, other normal | chuck hoppe | Propulsion | 8 | 03-22-2007 09:12 AM |
| normal at forefoot | rhiemstra | Software | 7 | 01-31-2007 01:15 AM |
| Heat Pump => Vacuum Pump | Inquisitor | Boatbuilding | 7 | 11-12-2005 10:29 PM |
| Is this noise normal? | scarmack | Powerboats | 0 | 06-07-2004 03:57 PM |
