Old 06-29-2006, 01:57 PM
Jburke Jburke is offline
Proper Flushing Of Jet Boat
Im looking for some insight on how to properly flush the entire cooling system on a 79 Thahiti w/Panther Jet. It has 454 Big Block, but the last time I took it out the temp raced to near red-line. Does anybody have any tips?
Old 08-15-2006, 05:42 PM
Riverjet502 Riverjet502 is offline
Rep: 15 Posts: 8
Just disconnect the cooling line coming off the jet pump (probably easier at the "Y" pipe) and attach a fitting to this line that will allow you to connect a garden hose to it. Very simple. On mine I just pull the cooling hose off the pump and slide a small piece of garden hose over the bib on the through hull fitting and flush away...
Old 08-15-2006, 07:42 PM
jburke1 jburke1 is offline
Rep: 10 Posts: 2
Overheating Issue
I've Flushed It As Instructed And Replaced The Thermostat With An "oe" One. It Is Still Getting Hot! With The Garden Hose Attached, Water Flows Evenly From Both Exhuast Ends. I Dont See Any Evidence Of Water In The Oil, So I'm Not Sure What Is Causing This Issue. Any Ideas?
Old 08-15-2006, 09:36 PM
Rep: 15 Posts: 8
OK it sounds like your t-stat is not opening. They don't like silt and sand very well. If you are using a automotive thermostat take it out and do not use it. I am assuming that you are running "wet" exhaust. If you desire to run a thermostat you need to run a thermostat byepass kit. Rex Marine or CP Performance sells these. I don't run a T-stat in my jet. My cooling comes off my pump goes through a thru-hull fitting then into a gate valve. From the gate valve the cooling is plumbed into a V-pipe which sends water to my Gill exhaust manifolds on each side of the engine. After the water is pre-heated from the exhaust manifolds it goes into the front of the block. After circulating in the block and heads it comes out the t-stat housing (which has no t-stat) where it dumps into the risers to cool the exhaust since I have an enclosed engine compartment. The reason for the gate valve is so that I can control the amount of water entering the cooling system. This also acts like a reducing valve so that I don't over pressureize the cooling system and milk shake my oil. Hope this helps alittle.
Old 08-15-2006, 10:26 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1514 Posts: 5,518
Exellent post --
Old 08-16-2006, 11:55 AM
Rep: 10 Posts: 2
Great help!!!! I really appreciate your recommendations. By the way, you solved my overheating issue. YES!
Old 08-16-2006, 12:26 PM
Rep: 15 Posts: 8
Glad to help out.....
Jet, Jet Pump, Waterjet, Jet Drive vs Prop brian eiland Jet Drives 45 08-27-2010 09:04 PM
jet boat sandrail Gas Engines 5 07-24-2007 07:33 AM
Proper permits/license for boat sales? jameshogan Marketplace 1 10-24-2005 12:23 AM
Flushing aluminum tank containing old diesel? Robert Miller Propulsion 2 01-10-2005 02:08 AM
