Old 04-22-2008, 02:43 PM
tooler1 tooler1 is offline
Rep: 10 Posts: 3
pp140 jet drive
hi firstly how can i check if i have a pp140 jet drive, There is no plate or
marking on the jet ( seller told me it was a pp140) it has a bronze impeller
with a 1mm gap to the housing,i think the rubber bearing on the back of the housing is gone,as the engine was started out of the water and we got a
burning rubber smell, it will drive the boat but at a slow speed it is married
to a v 6 ford 3 ltr essex engine. Hope i made sense thank's for reading
Old 05-16-2008, 09:02 AM
anthony goodson anthony goodson is offline
Rep: 241 Posts: 391
Hi
it's unlikely to be a pp140 if its coupled to a ford v6 A pp140 has a 14inch [356mm] diameter impeller, post a picture Tony
Old 05-16-2008, 09:35 AM
Rep: 241 Posts: 391
Hi
Old 05-16-2008, 03:29 PM
Rep: 10 Posts: 3
re ppjetdrive
hi anthony,
thanks for the reply, i have found out it's a pp65 jet thanks:
Old 05-17-2008, 05:52 PM
Rep: 241 Posts: 391
You have then,probably found out that this jet doesnt have a rubber rear bearing ,it has a DU bush made by Glacier Bearings and can be run out of the water without damage
Regards Tony
Old 05-18-2008, 04:06 PM
Rep: 10 Posts: 3
re jetdrive
thank's again Anthony.
i have been on to the maker's of ppjet's for some
spare parts, they did'nt mention that baring, I only need a few washers
and seals, the impellor and the shaft is perfect,also the engine is running
perfect a ford v6 3ltr
Old 05-18-2008, 05:26 PM
Rep: 241 Posts: 391
Parts from Vospower are very expensive but most including the DU bush are available from your local bearing supplier as they are all standard sizes,but make sure you specify stainless steel springs in the seals, these are quite common now as they are used in the catering industry When you remove the impeller be very carefull not to damage the polyacetal {plastic} bush ,these are fragile and costly
Regards Tony
Jet, Jet Pump, Waterjet, Jet Drive vs Prop brian eiland Jet Drives 45 08-27-2010 09:04 PM
Converting from Jet drive to Stern drive gearhead496 Boat Design 9 03-22-2008 12:23 PM
help old jet drive ahoyjohnboy Jet Drives 0 11-01-2007 04:22 PM
jet drive? or stern drive? Toby100000 Jet Drives 2 08-04-2007 04:32 AM
jet drive pricey797 Jet Drives 2 05-30-2007 04:40 AM
