Old 02-12-2008, 09:15 AM
sean_manning sean_manning is offline
powered body board
I am currently working on a project where I am making an electrically powered body board,
I am going to be using 2 impellers. It will need to power the weight of 2 people through the water at, at least 5mph. I am only looking at a duration of 30 minutes and have already found two 500 watt motors (total 1000w) which will rotates at 4000rpm each for the required time.
Where I fall down is on choosing the impeller that will give me the required speed and knowing whether the RPM is adequate.
Any assistance would be so helpful and any impeller makers would be brilliant
Thank You
Sean
Old 04-02-2008, 05:02 AM
david1young david1young is offline
Rep: 10 Posts: 5
try connacting some diving scooter manufactuers
as that should be same type of thing
Old 04-08-2008, 11:19 PM
tkinak tkinak is offline
Rep: 10 Posts: 31
These are kinda cool. You could conver one to electric.
Sorry that's all the help I can be.
http://www.mokai.com/
http://www.surfango.com/index.htm
Center-board r.mike Boat Design 2 01-21-2008 08:55 PM
better body plan CapKos Boat Design 4 05-07-2007 04:34 AM
how do you make your own fiberglass body huntermike32 Fiberglass and Composite Boat Building 12 11-02-2005 06:43 PM
glassing over body filler? LKJR Fiberglass and Composite Boat Building 4 05-27-2005 03:47 PM
Affixing full keel to canoe body RDB Boat Design 0 05-17-2004 06:58 PM
