| OMC to Berkley swap I just bought a 1974 Cobalt 18 ft. tri hull with a 307ci. chevy OMC enginewith a berkley pump,the last owner told me that it had originaly had a OMC jet.The same time I found this boat there was another one equipted the same,my question is was this a fairly common conversion and what kind of performance can I expect from it.I'm mainly going to be doing some recreational skiing and towing grand kids around on tubes. |
| Are you sure it is a 307? That sounds like a Pontiac engine.
__________________ Gonzo |
__________________ brendan . |
| Yes I'm sure it's a chevy.They put them in cars from about 68 through the early 70s and made the marine version for OMC rated for 210 to 245 HP depending on the year. |
| As far as I know OMC never made a jet pump but put their name on a Berkeley for a short while, just like Mercruiser did in the past. Because of the poor performance compared to stern drives they quickly abandoned the idea and sold it under its own name again.
| I -think- Mercruiser was a panther jet. Anyway, It should work fine for tubing with the kiddies etc. -jim lee |
| Thanks everybody, if it seems low on horse power for next season I'm looking at putting a small block 383 stroker in that I have left over from a stock car. |
| If you need pump work in So Cal. Talk to Jack - Marine Performance designs 949-631-2040 Good luck! -jim lee |
| 1970 omc engine swap | en3forever | Sterndrives | 1 | 07-14-2008 12:55 PM |
| Swap out a Jacuzzi for an OMC!!! | idahorunabout | Propulsion | 3 | 06-10-2008 07:13 PM |
| OMC I/O 800 Swap out whats possible? | firestorm | Propulsion | 1 | 05-11-2006 11:52 PM |
| Swap 302 omc for 351windsor omc king cobra outdrive | allen | Powerboats | 6 | 04-11-2006 12:10 PM |
| Engine swap OMC to Mercruiser 4.3 | CreoleIII | Propulsion | 0 | 05-17-2005 09:36 PM |
