| oil in a pp 60 jet Hi guys i read some were on here that a pp jet need oil as i stripped my jet down and found no place for oil let alone any oil, Were would the oil go as im about to give my boat sea trial's and would hate for some thing to seize thru me not asking the pro's were and how to get to the iol. diagrams would be great if you could help. here or at montyrosevear@aol.com |
| If its a PP 65 you have, then the DU bush in the stator centre should be lubricated with EP 90 or similar. Remove the stator housing and fill the centre cavity about one third full. Be careful not to turn the lip of the seal or hydraulic it out as you replace the stator unit. |
| Jet, Jet Pump, Waterjet, Jet Drive vs Prop | brian eiland | Jet Drives | 45 | 08-27-2010 08:04 PM |
| Jet Pac jet drive | quikfix51 | Jet Drives | 1 | 07-28-2010 08:45 AM |
| electric oil pump for oil changes and priming | simon | Diesel Engines | 13 | 11-14-2008 05:54 AM |
| how often to change oil on 454 chevy jet | holdthegroove | Powerboats | 4 | 06-30-2005 06:24 PM |
| No water in oil pan, But water in oil filter? | midtower | Gas Engines | 14 | 03-19-2005 05:43 PM |
