| No forward / reverse thrust Hello All - I have a Boston Whaler jet boat with a 90 HP Johnson motor. After having it worked on last year, cleaned out, I finally got it started. I can get the engine to remain running and can move in a forward or reverse motion, and increase RPM's, still the boat only travels at about 2 MPH ... feels similar to a car with a transmission problem ... Any ideas / suggestions would be greatly appreciated. |
| Have you checked your shear pin? Do jet boats use a common shear pin? Alan |
| Hey--- I know Westminster--- had a Jehovah Witness girlfriend there one time long ago, not too far fron Rte 2. My brother now lives in Princeton. |
| check the shimming of your impellor if plus .030 move shims from bottom of impeller to top this will bring the impellerdown into the liner and give you more thrust once the clearance is correct |
| Thanks for all the advice, guys, but as my girlfriend says "yikes" ... I'm not that mechanically inclined ... Barry |
| Through Hull Scoop Forward? | S Hondros | Boat Design | 3 | 09-26-2006 01:55 PM |
| forward rudder hydroplanes | moTthediesel | Boat Design | 7 | 09-07-2006 11:49 PM |
| Forward looking underwater radar | Lyle Creffield | Open Discussion: All Things Boats & Boating | 1 | 07-09-2006 10:16 PM |
| Forward props | Akeswins | Props | 8 | 06-10-2005 09:48 PM |
| Linux, CAD, and the way forward | Tim B | Software | 20 | 11-25-2004 06:29 AM |
