| Modifying a water jet for passages (Different design point) I am not looking for variable geometry water jet or any such nonsense or permanently changing the set-up. What I am asking is if it is possible to temporarily set up a sprint vessels water jet system to perform better on a long passage, hopefully with only minor changes to inlet and outlet diameters. The design point was around 55 knots but for a passage 18 knots on the plane or 10 knots displacement speed would be needed. Propulsion efficiencies where calculated to be 28% at 10knots and 35% at 20knots so it would seem there is room for improvement, but not that it's realistic. I assumed that more inlet flow would be needed and the only idea I could come up with is a removable moulded skirt on the inlet duct lip (slight scoop)? |
| Might be possible, depending on "as built" status. Send me a mail with all relevant info on hull, engines and jets; i'll see what can be done without a complete rebuild. |
| Water Passages | kenJ | Outboards | 5 | 04-06-2012 02:37 PM |
| Design help? (modifying bass boat freeboard, sheer line) | shakey78 | Boat Design | 4 | 02-19-2012 04:24 AM |
| GRP 37ft - strong enough for true offshore passages? | mattplowman | Sailboats | 6 | 03-20-2008 11:41 PM |
| Water jet | Wellydeckhand | Powerboats | 7 | 05-11-2006 08:39 AM |
| Water Jet. | John@AMO | Boat Design | 0 | 06-20-2005 02:09 AM |
