Old 09-06-2011, 01:08 AM
telrunya telrunya is offline
Lateral motion by twin waterjets
Hi all
I'm interested in using twin waterjets and I'm curious on how it provides a lateral thrust to the boat without yawing.
Can anyone explain what's the combination of machineries (i.e. nozzle, bucket, throttle) that produces a lateral thrust to the boat?
Thank you!
Old 09-07-2011, 02:26 PM
BMcF BMcF is offline
Rep: 191 Posts: 459
It's a simple vector addition. Typically, both jet units are turned outward/outboard and one placed in forward and one in reverse. The fore-aft thrust vectors cancel and you are left with only the residual combination of side thrust vectors, which side direction depending simply on which unit is in the forward bucket position and which in reverse.
I had a simple diagram somewhere that shows what I described above. I'll try to find it.
Old 09-08-2011, 04:06 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,253
The large catamaran ferries here use such a system.
Nozzles and buckets are articulated by hydraulics, but the actual controls are electronic: Two joysticks, each controlling one jet and the corresponding engine, plus a lock/unlock switch for normal navigation and docking.
Old 09-08-2011, 04:11 AM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
not great though as many of the large high speed ferrys have smacked the dock
For their windage they need something more
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
CAD Drawings of waterjets? D_Mylonas Jet Drives 4 05-14-2007 06:03 AM
Tuning the pitch of Waterjets simonB Boat Design 1 08-09-2005 10:38 PM
Savitsky correction for waterjets? nemo Boat Design 10 05-02-2005 08:00 PM
NZ (other) prices for Waterjets Danielsan Marketplace 1 03-18-2005 07:13 PM
2 small waterjets in a 8 m boat mselle Propulsion 3 10-23-2004 01:09 PM
