Closed Thread
Old 10-18-2011, 07:43 PM
nbehlman nbehlman is offline
Rep: 10 Posts: 21
jet power on warped bottom hull?
I am planning to build a 14 foot runabout in the style of the early 30's and 40's chris crafts. The power plant is a 70hp TigerShark jet ski motor and pump. I am designing the hull from scratch and I wanted to see what the experts on this forum have to say. If you have any comments or advice on what types of design features I should incorporate into my hull, please share them! Here is some basic info:
http://nbehlman.com/hullprofile.png
length: 14ft
beam: 4.8ft
weight: 650lb (jet ski weighs 476lb)
deadrise: 6.5 deg
draft: 6.5 inches (one person aboard)
Are there any special considerations I should take into account when designing a hull for a jet drive? These hulls are meant to take an inboard prop. I have noticed that jet skis have a much more rounded hull, while my boat will have sharper chines and a low deadrise vee bottom.
I have looked around on the internet for similar projects and there seem to be quite a few. Most of them are simple "what happens if I do this?" type projects. I came across one site that shows a very strange profile below the waterline:
http://www.sponbergyachtdesign.com/D...le%20small.jpg
It looks to me like it would create massive amounts of pressure drag because of the keel line near the intake.
I found a video of a chris craft converted to a jet drive:
http://www.youtube.com/watch?v=uBUUeNfGjTg
At the 10 second mark, you see it go into a drift turn characteristic of jet boats. I am concerned that these kinds of turns could cause the hull to "trip" over the nearly square chines.
I expect that my hull will provide a great deal more lift than the jet ski hull, but will of course weigh more. I have done quite a bit of work with the Savitzky power prediction method, but I suspect it is not very accurate for jet boats since the kind of suction onto the water. My target speed is 30 mph. The jet ski currently does 40 mph.
Old 10-18-2011, 08:24 PM
Boat Design Net Moderator Boat Design Net Moderator is online now
Moderator
Rep: 647 Posts: 184
Crossposted; let's keep the discussion together in one thread at
Jet power on warped bottom hull?
Please be polite to all other members. Please respect those who take their time to give advice freely. And please keep threads on topic. Forum Rules
Closed Thread
Jet power on warped bottom hull? nbehlman Boat Design 8 10-21-2011 04:12 PM
Jet power on warped bottom hull? nbehlman Hydrodynamics and Aerodynamics 1 10-18-2011 08:24 PM
26' Pad bottom with 2 step bottom hull mold only johnboat75 Marketplace 1 03-07-2009 07:00 AM
Warped Bottom Designs wdnboatbuilder Boat Design 46 01-06-2006 10:35 PM
Monohedron vs. Warped bottom Paul Dean Boat Design 5 05-21-2003 12:03 AM
