Wow, this thread is getting old. Fortunately, the subject matter is still much on the minds of many.
With regard to the comment about boat weight not changing the load placed on a jet... how much does the static weight of a boat change when it becomes airborne? Or conversely, how much additional torque load is placed on a jet drive system when one adds, say, 500 lbs. of diesel fuel to a boat?
I think that was more of what the statement referred to, that increasing the mass of the boat did not increase "load" on the jet. Increased mass (weight) of any given hull will, of course, change the performance of that hull based by additional hull resistance due to additional "wetted area", and certainly, we have seen differences in "mileage" , affected (sometimes severely) by overloading, but does additional mass in any given hull change the torque load on a jet? Not according to anything I've read from any of the manufacturers.
And I'm not sure that airborne operation is an important design criteria when choosing a propulsion system for a fast ferry.
However, you are absolutely correct, the torque load on a jet drive does change when you take the boat out of the water.
(BTW, the day my 11000 lb. 30 ft. Reinell Flybridge with the twin diesels becomes airborne or starts chine walking due to excessive speed, I'll post a picture of my shorts!
For the most part, and I may be stretching here a bit, I don't perceive that the majority of contributors here are primarily concerned about launching their boats into the air. I'm sure that there are probably a good many sites that are more attenuated to the "go faster" crowd.
Meanwhile, the relationship between thrust, flow, pressure, horsepower, torque, and the myriad of
factors surrounding this type of propulsion system still defy our attempts to simplify it. The one thing I have noticed from all the manufacturers websites and case studies is a propensity towards throwing a lot more power at jet drive systems. Very few (none) are touting economy or "efficiency", (think I'll leave the lid on that can of worms), the key buzzword seems to be "performance".
Heck, my boat would "perform" better if I threw a couple af 500HP diesels at it too!
So what it seems to come down to is that Jet drive propulsion becomes a choice that is made by weighing a certain set of criteria. In my own case, the choice will be made based on my own set of criteria, which, in no particular order seem to be:
1. shallow draft operation
2. ease /simplicity of installation
3. reliability/ serviceability
4. safety/environmental impact
5. reduced operational maintenance - no fluids to change, cool, or recycle
6. all that expensive stuff that hangs down under my boat goes away
7. reduced weight - 2 jets weigh less than 1 veedrive+1 shaft+1prop+1 strut+1 rudder+1 thru-hull hardware group
The process is underway. The boat is on the hard, I'll keep you all posted.
