| Jet Drive on Tunnel Hull Possible? I want to put a jet drive on a 16 foot alum Monarch tunnel hull boat. Is this recommended? I run in a lot of sandy areas and very shallow water. |
| This is a tunnel hull and it is propelled by a jet drive. Actually by a 500ci V8 hooked to a jet drive. 132 mph in the 1/4 mile. high 7 or low 8 sec. I forget. So yes, you can successfully run a jet drive in a tunnel hull. -jim lee |
| There are lot's of tunnel hulls powered by jet drives. Good designs will perform very well.
__________________ /Jimboat AeroMarine Research 'Secrets of Tunnel Boat Design' book 'History of Tunnel Boat Design' book 'Secrets of Propeller Design' book 'Tunnel Boat Design' software w/'Vee hull design' & 'Porpoise Analysis' 'PropWorks2' software 'Vee Hull & Vee Pad Design" paper 'BoatDesign.net article on Tunnel Boat Design" |
| MR. CBM - it's hard to consider one design as best overall, since it really depends on what your performance objectives are. Southwind, California Performance and Eliminator all make very good, fast jet-drive tunnel hulls.
| Southwind, California Performance and Eliminator are all successful drag boat hulls. "you can always improve" on a design, since many successful designs have been around for many years without modifications. so there is always a way to improve a design to achieve just what you're looking for.
| Jet, Jet Pump, Waterjet, Jet Drive vs Prop | brian eiland | Jet Drives | 45 | 08-27-2010 09:04 PM |
| DIY tunnel drive | CDK | Surface Drives | 206 | 08-22-2010 06:43 AM |
| Tunnel drive performance issue | CDK | Boat Design | 113 | 08-18-2009 07:31 PM |
| A new guy's hello and plan. Jet drive Tunnel hull. | Coreyjon | Jet Drives | 3 | 11-10-2008 01:09 AM |
| Flat Bottom Jet Tunnel | dick stave | Boat Design | 4 | 04-14-2006 02:56 PM |
